Old 12-26-2007, 11:45 AM   #1
N2XBW's Avatar
BRADENTON, On The Picturesque and Sunny West Coast of Florida, , USA, PLANET EARTH, MILKY WAY, LOCAL GROUP, SPIRALING SLOWLY THROUGH THE UNIVERSE
Question Two Out of Three Ain't Bad...
My Fellow Alumilovers,
The fridge in my '84 Excella 270 MH works 100% on both 110v AC and propane.
The 12v DC function does not operate.
Any suggestions as where to start? Thanks in advance.
John / N2XBW
These aren't the droids you're looking for.
You can go about your business.
Move along.
N2XBW is offline   Reply With Quote
Old 12-26-2007, 12:01 PM   #2
John / N2XBW
If it's the original, it does not have a 12 volt set up.
What is the model number?
Old 12-27-2007, 09:16 PM   #3
Joe Z's Avatar
Andy - That particular motorhome did have a 3 way fridge as original equipment from the factory. Also, the wiring diagram in the 1984 Airstream Motorhome Owners Manual shows a 25 amp fuse on the chassis fuse block that powers the wipers and the refrigerator.
John - First thing I'd do is confirm that the fridge is actually receiving power from the chassis fuse pannel. To do this first check to see if the wipers are working (as I mentioned above the fridge and the wipers are on the same fuse). If they are then you know the fuse isn't blown. Next I'd check the wires at the fridge to see if you are getting power from the chassis fuse block (seperate from the ignitor run) which should come from the coach battery. If you have power on the chassis wires then you know it's the fridge.
Let us know what you find. If power is confirmed someone else on the forum will need to jump in and help with diagnosing the actual refrigerator 12V operation.
Good Luck!
Joe
Joe Z is offline   Reply With Quote
Old 12-28-2007, 08:07 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Having 12v is not always good. I don't know if it's just coincidence, but the 3 way fridges that I have seen with bad circuit boards have been running on 12v. The 3 way fridge in our Overlander was deliberately left off the 12v feed for cooling.
Old 12-29-2007, 11:01 AM   #5
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
I agree with Terry.
I did not hook up th 12V in my Flying Cloud either. When I don't have 120V I use propane. I don't want to kill my battery by mistake and then be without that resource to run everything else.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
how bad is too bad a dent? prairieschooner Exterior Restoration Forum 26 07-21-2010 01:40 PM
Bad as it looks? sumsmug Repairing/Replacing Floor &/or Frame 4 09-17-2007 09:44 AM
What is this...can it be bad?? dragonnfly Electrical - Systems, Generators, Batteries & Solar 11 05-28-2006 02:41 PM
Bad Bad Things... (a new 454 Engine?) pillageTHENburn Mechanics Corner - Engines, Transmission & More... 24 12-19-2005 12:49 PM
How bad have you got it? 69Ambassador Our Community 6 10-25-2003 04:08 PM
