06-06-2020, 11:53 AM
#241
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Traveling while refrigerator is running on propane
Given we have 400AH of lithium batteries and 650 watts on the roof, we usually run the fridge on electric while we drive. It’s just so easy, so snide remarks aside, why not reduce an obvious potential risk when we can do that so easily? The one possible exception would be when we know we’ll be dry camping several days at our destination and want to start off with a maximum charge on the batteries in case we will be camped in the shade.
06-07-2020, 08:40 AM
#242
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
AC is a big draw for fridge, using batteries. The new 3 way with DC is a better choice when plugged in to your TV while traveling, IMHO. Propane has worked for us over 18 years now, with 4 AS's, without much fuel used. Reliable and efficient. I agree; save your batteries for camping.
06-07-2020, 01:08 PM
#243
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
We have for over 40 years, even with the old 3-way ones. Only turn it off when running thru tunnels that don't permit propane on.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
06-29-2020, 05:23 PM
#244
2020 25' Flying Cloud
lake Wales
I have a 2020 FC 25. After reading all the posts, I decided to keep the LP on and the refer running between stops. We are in Florida and the SE and it is so bloody hot. However, the refer does NOT stay running while we are towing, even with the LP on. Have they changed the system? When we get to our next camp, after 8 hours, the freezer is defrosted and the refer about 60 degrees.
Is there a trick to keeping it on?
e
06-29-2020, 05:31 PM
#245
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Does it stay running or does the flame blow out?
06-29-2020, 05:49 PM
#246
2019 27' Globetrotter
McHenry
e
Flathead, check to see if your fridge is on “auto”. There have been reports of issues with using the auto function. I press the flame icon to manually select propane. Check the outside access panel to ensure there’s a flame before taking off.
We have a 3-way fridge in our Globetrotter. I ran it on 12V for the first two stops (we have solar) a few weeks ago on the way to Colorado. I use my Thermopen Smoke grill thermometer with wireless remote to monitor the freezer and fridge temps when driving. If I notice the temp rising, I’ll switch it to propane. It’s reassuring to know what’s going on in the trailer and not loosing food when you arrive.
NOTE: The two photos were taken at different times; that’s why the fridge temp on the remote is different than the main unit. You can program upper and lower alarm limits. They’ll beep at you when they get out of the set range.
Hope that helps!
Jeff
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
06-30-2020, 02:44 AM
#247
1977 Argosy 28
Euless
Refrigerator not cooling on propane
Does is cool on propane when you are not driving? If not, you may need to clean the jet. Mine quits cooling and I have to clean the jet about once a year. Turn off the gas, remove the sheet metal cover and you can see the brass jet and unscrew it. It will probably take a metric open end wrench. Soak it in denatured alcohol for about 15 minutes and then blow it out with canned air. DO NOT USE A WIRE TO TRY TO CLEAN IT OUT. Modern jets have a very synthetic ruby tip with precise diameter opening. A wire can knock that off and you have too much gas and a potential fire hazard. The trick is getting it back in. It's a tight space. I use the next size box end wrench to hold it in place while I screw it back in with the right size open end wrench.
Airflow is another factor that may be your problem. Cooling relies on air rising up and passing over the cooling fins on the back at the top of the Refrigerator. If the airflow is disrupted it will not cool. You might benefit from installing one or two 12v computer fans blowing up over the coils to insure the air goes the right direction. I did this but found I only need those if it is over 95 degrees. They will, however, make sure air is flowing up not down.
When I am traveling I freeze water bottles or ice packs in the freezer at night while on shore power then put them in the refrigerator while I'm driving to help keep the lower box cold. In hot weather I also turn the refrigerator setting down so it is just above freezing in the morning so it starts out colder and takes longer to warm up. Ideally your refrigerator should be below 40 degrees all the time.
Past President, Vintage Airstream Club, WBCCI # 7291
1977 Argosy 28 Center Bath (CA made) and 2015 Ford F250 6.7 diesel. Used to own 1978 Argosy Minuet 6.0 and 2013 Toyota Tundra
07-01-2020, 09:41 AM
#248
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
We run our fridge on propane whenever we are in motion. The switch never goes off the "auto" setting. Never had a problem during at least 100 "in transit" days out and about.
07-01-2020, 11:15 AM
#249
, Texas & Wyoming
Hi
Ditto!
07-01-2020, 11:45 AM
#250
Tampa
I have a routine.
It probably doesn't make sense, but it works for me.
When switching from "on" to "auto", I turn it off first.
I feel that I give it a better chance of lighting.
My old RV I could hear the "whoosh" of the flame lighting.
I don't hear that in the Airstream, so I'm always grateful when it's cold or colder at the end of the day.
I understand the orifices need cleaning periodically, but so far so good.
"If it ain't broke, don't break it."
