Old 02-21-2007, 02:03 PM   #1
1981 31' Excella Limited
Statesboro , Georgia
Tips on refrigerator installation?
I am swapping out a Dometic RM 100 for a RM 2820, and looking for any tips or tricks on the making the process silky smooth. I downloaded a set of instruction on installation, and it seems straight forward. However, I find that almost to good to be true. I'm waiting for the delivery of the fridge, and trying to do a little pregame toruble shooting.
Any input would be greatly appreciated.
Scott
___________
borostreamer
1981 Excella Limited 31'
2004 Toyota Tundra
1993 Land Cruiser
1995 Mustang Cobra
borostreamer is offline   Reply With Quote
Old 02-21-2007, 02:10 PM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Scott-
Right now all I'm going to do is send out positive waves so that this project goes as smoothly as possible. I will not hinder you or your project with any concerns or negtive comments. I expect to see a post from you in a few days with photos of the instalation complete and trouble free!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-21-2007, 02:13 PM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I did this last year. So easy a neuroscientist could do it . As I recall, all it involved was running a wire for the ignitor, connecting the propane, pluging in the shore power cord, and attaching the fridge to the deck.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-21-2007, 02:32 PM   #4
Neuroscientist, HUH? If it is that easy, I don't know what I'm stressing about.
Think positive, right!
Scott
___________
borostreamer
2004 Toyota Tundra
1993 Land Cruiser
1995 Mustang Cobra
Old 02-21-2007, 02:43 PM   #5
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Physical exterior dimensions may be "off.."
One of the common issues seems to be a few silly millimeters (or eighth's) of difference in exterior height and width. This can creat issues requiring filler strips or router work to make hole inside fit exterior of new box, and make the door panels not look as good as they should... Mostly cosmetic concerns, but Dometic doesn't seem to feel all "medium size refrigerators" need to be the same exerior dimensions...
Good luck with yours...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 02-21-2007, 04:38 PM   #6
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
We're going to have the same project once ours arrives (dead MA52 against a new RM7401). Yep, there's going to be some trim work to do in order to make it look nice: The RM7401 is just a smidgen smaller than the old MA52. I figure I may need to reroute the propane feed a little bit, too, but that's not such a tough job. Potentially most challenging would be to deal with wiring: The RM7401 may (or may not) require a 12v feed. (The MA52 had none such.)
Lynn
WBCCI 21043
Old 02-21-2007, 06:41 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
Lots of screw points!!!
I've removed refers in some trailers and MoHo's that had as many at 12 screws holding them down. The # varies with the OEM manufacturer. Just be sure that you put 2 in the back and 2 in the front at the bottom. The instructions should pinpoint the exact recommended locations. A lot of Dometic refers also require screws at the top, usually hidden by the control panel (eyebrow).
If your cabinet is relatively snug on the top and bottom this should not be a problem. I would say a minimum of 6......2 bottom front, 2 bottom rear and 2 top front. More if you feel the need.
Remember, this thing will be bouncing and swaying down the road, and you sure don't want it breaking free and smashing thru the other side of the trailer in an emergency situation! (hoping that you NEVER have one!!!)
Old 03-18-2007, 04:58 PM   #8
1990 34' Excella
Windcrest , Texas
Seals
We are getting ready to pull out the 110 V refer that came with our AS and replace it with a RM 2820. In reading the notes there were suggestions about adding a 'combustion seal' to the interior of the trailer. It basically seals the inside of the trailer away from the back of the frig incase of a propane leak.
Anyone heard of this and if so does it come with the frig?
Swanny is offline   Reply With Quote
Old 03-18-2007, 05:07 PM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Swanny,
I would think the "combustion seal" would be to keep Carbon Monoxide from getting in the trailer rather than the LP. I have not paid attention to how the newer units are installed. I know the one on mine was not done correctly because when running on LP it would drive the CO detector crazy. When I reinstall it, the bulkhead will be sealed to the walls and the fridge casing to the bulkhead frames, probably with either a tape sealant or a rubber bulb seal of some type. I don't think it will come with the fridge it is probably and added cost item.
Aaron
WBCCI #XXXX AIR #2495
Old 03-18-2007, 05:17 PM   #10
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Yep, I just worked on sealing the new fridge (RM7401) today. Basically, because the new one is smaller than the old one, I had to do some wood work around the perimeter anyway. However, rather than just wood strips as trim, I cut out somewhat larger strips of foam and glued the wood strips to them. Then pushed the wood strips in around the fridge so that there is a positive seal all around.
Lynn
WBCCI 21043
Old 03-18-2007, 05:34 PM   #11
lewster's Avatar
Any type of seal that will provide an air tight fit will work. A lot of OEMs use the dreaded 'silicone' and it just peels right away when the refer is removed the first time.............................worthless!!!
I would suggest butyl tape around the entire inside edge of the refer flange. Be sure that it's continuous so there won't be any leaks. You sure don't want your LP detector to go haywire at 02:30 when you're boondocking somewhere!
Old 03-18-2007, 07:08 PM   #12
Exeter , Rhode Island
When I replaced my refer with a RM 2820 I had a gap at the top at the control panel. My AS is an 89 Excella. Since you are replacing a 110 V refer I not sure what mods you may have to make. The RM 2820 that I installed had seals around the edges. I secured 2x4 lumber on the sides and front of the opening and set the refer on to raised my new refer to eliminate the gap at the top. I purchased an additional sealing strip to seal the bottom.
Rob30044 is offline   Reply With Quote
Old 03-19-2007, 01:38 PM   #13
1990 34' Excella
Windcrest , Texas
Great Feedback Everyone!
I'll take these to heart when the frig comes in.
I ordered one from Jevin today at Palomino parts and the AS price is $850. When I asked about them being quoted cheaper on our site he stated that was only when they are overstocked
He did ask me to post the new phone numbers. This is his direct line so you don't have to go through the front office.
(269) 432-9791 or 1-800-297-5830
By the way I ordered a Dometic RM 2820 which was at least $1150 anywhere else I looked. The shipping is $125 with Palomino.
Old 03-19-2007, 03:49 PM   #14
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I just finished the install on the Ambassador.
I had to build a bulkhead wall to enclose the fridge. I used butyl tape on the back of the wall edge before I secured it in place.
I built a wood frame enclosure for the fridge flange to slide into. The flange has foam strips on it for a seal. I used six screws, on the front two at the top, two at the bottom, then two in the rear.
Another point to consider is to not leave more than an inch open on the rear of the fridge across the top. This would allow heated air to circuilate around the top of the fridge and heat it up. I just blocked off the top of the fridge entirely from the rear.
-Tim
theVAP - Airstream Podcast
Quicky Hints and Tips FrankR General Repair Forum 7 10-05-2012 10:09 PM
Polishing tips? Rog0525 Cleaning, Stripping & Polishing 10 04-30-2007 08:27 PM
Tips for installing wood flooring? 64GT Repairing/Replacing Floor &/or Frame 31 12-05-2006 11:00 PM
Tips on backing up and Turning radius NewStreamer On The Road... 36 08-12-2006 08:27 PM
winterizing tips for 1971 Safari frydmans Winterizing, Storage, Carports & Covers 9 11-25-2002 06:50 PM
