Old 03-19-2007, 06:31 PM   #15
lewster's Avatar
Naples, FL , Hood River, OR
Tim,
Many of the install manuals show a baffle placed at the top of the fridge to direct the hot air out the upper vent and keep it away from circulating above the fridge. You got it right!
Old 03-20-2007, 07:25 AM   #16
1990 34' Excella
Windcrest , Texas
Where to get it
Originally Posted by Safari Tim
I had to build a bulkhead wall to enclose the fridge. I used butyl tape on the back of the wall edge before I secured it in place.
Is butyl tape something I can pick up at Home Depot or Lowes?
Swanny is offline   Reply With Quote
Old 03-20-2007, 09:50 AM   #17
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I had better luck with Ace Hardware. They may call it putty tape or mobile home tape. It was near all the caulking tubes.
-Tim
theVAP - Airstream Podcast
Old 03-22-2007, 08:19 PM   #18
1981 31' Excella Limited
Statesboro , Georgia
Any one have tips on getting my old rm 100 out? I've removed every screw I can find, and the fridge will not move. I' ve tried a pry bar to no avail.
Any suggestions? Help?
Scott
___________
borostreamer
1981 Excella Limited 31'
2004 Toyota Tundra
1993 Land Cruiser
1995 Mustang Cobra
borostreamer is offline   Reply With Quote
Old 03-22-2007, 09:26 PM   #19
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
I am reading this and I am feeling some anger. Anger at the installer we paid big bucks to put our new fridge in for us. The top of the fridge cabinet in our '77 Overlander gets quite warm. In fact the side cabinet gets quite warm as well. We now have to leave the side and top cabinets open to dissipate the heat that is building up.
I am guessing that we have a bad sealing issue and that I am going to have to pull the fridge and seal the entire thing.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 03-28-2007, 12:48 PM   #20
1990 34' Excella
Windcrest , Texas
RM 2820 Install
In the install manual there is no reference to any baffles. It simply says, "Center the coils below the roof vent."
Is this accurate? I was thinking there should be a pipe from the back of the fridge to the roof but when I looked on the back of the fridge there is no exhaust pipe that looks like it should be hooked to anything.
Any tips?
Old 03-28-2007, 01:50 PM   #21
Dan@LED4RV's Avatar
Denton , North Carolina
Hopefully you will have a close place to import 12 volt from as the RM 2820 Needs 12volt. The most important thing,as Wahoonc pointed out, is that you do seal the unit so that you do not have Carbon Monoxide get in the trailer, even if you have to sacrifice appearance.
Dan@LED4RV is offline   Reply With Quote
Old 03-28-2007, 03:28 PM   #22
1990 34' Excella
Windcrest , Texas
We have 12 vdc
This is a replacement fridge so there is already a drain, 12vdc and propane line. It just seems odd that there is not a 'smoke stack' like I envisioned. From the installation manual it looks like the lower vent (which we have) serves to creates a draft that goes out the the upper vent. No 'smokestack.'
Old 03-28-2007, 03:43 PM   #23
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Swanny,
Sounds like you got it. The lower vent brings in the air, makes a draft and runs it out the top.
The things we were talking about here was just to make sure you isolate the rear of the fridge from the living area. My fridge came with a 1/2 lip all the way around with a foam gasket. It was meant to have an opening just big enough for the fridge to slide into and form a seal.
The manual shows if the top of the fridge has an opening to the back of more than 1", it needs to be blocked off because the heated air will circuilate around the top of the fridge and make it less efficient.
If the fridge stand away from the wall, some people add aluminum baffles to direct the air over the coils on the fridge.
-Tim
Old 03-28-2007, 07:08 PM   #24
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
Scott:
I just removed the Dometic 1303 from my 345 today, and found 6 "extra screws". The shop manual mentions the 6 that are in the front and covered with rubber caps. When it wouldn't move I found 6 more in the cabinet above the frig that came down into the top of it. Check your cabinets above and below. Ron
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 03-29-2007, 10:35 AM   #25
1990 34' Excella
Windcrest , Texas
Swanny,
I think this means there is more than 1" from the top of the fridge to the upper edge of the enclosure. If so what do you block off this area with?
Would it be something as simple as a foam pad?
Thanks---Mitch
Old 03-29-2007, 11:13 AM   #26
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Thanks---Mitch
I used a block of wood.
It just depends on your configuration. On my last trailer that had an abs chimney running up the wall. There was an aluminum baffle installed at the top of the fridge and run up to just inside the chimney.
Your really just trying to keep the air running up to the roof or side upper vent without any place else to go. Clear easy path.
It does get hot back there, so you would not want anything that would melt or be flammable.
Here is the manual for your fridge.
-Tim
Old 03-29-2007, 01:00 PM   #27
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Thanks---Mitch
I put in a piece of compressed foam insulation on top of ours, it seems to help a lot.
Old 03-30-2007, 07:44 AM   #28
1990 34' Excella
Windcrest , Texas
Great tips!
Thanks everyone.
This helps clarify what the instruction manual is talking about.
During installation is it a problem to tip the fridge? By tipping I mean haviing to really lean it one way or another to get it into the AS. Just want to make sure I don't damage anything by doing something wrong.
Mitch
Quicky Hints and Tips FrankR General Repair Forum 7 10-05-2012 10:09 PM
Polishing tips? Rog0525 Cleaning, Stripping & Polishing 10 04-30-2007 08:27 PM
Tips for installing wood flooring? 64GT Repairing/Replacing Floor &/or Frame 31 12-05-2006 11:00 PM
Tips on backing up and Turning radius NewStreamer On The Road... 36 08-12-2006 08:27 PM
winterizing tips for 1971 Safari frydmans Winterizing, Storage, Carports & Covers 9 11-25-2002 06:50 PM
