Originally Posted by jiffypop
I have a Norcold fridge from 1960. I finally found the pilot light. It has a red button on the front. When held down the pilot lights and the fridge lights. Once you take your finger off the red button the fridge goes out. No more blue flame. I've tried holding the button for 5 mintutes. Any ideas? Thanks
JP,
I agree with Marshall. My first inclination would be a bad thermocouple. It could also be dirty or mis-aligned. The T/couple should be located in the pilot flame to allow it to react to the heat of the pilot and have no rust or scale on it. I would remove the burner section and thoroughly clean everything, then re-install it and see if it works.
You can also check the gas valve by applying 12 VDC directly to the contacts. If you hear a click....it's probably working.
Try these and let us know how you make out.
lewster
