Old 06-21-2015, 07:58 PM   #1
tarh2o's Avatar
1975 25' Tradewind
Boerne , Texas
Question Temperature Control Knob Setting
Well I originally thought that my dometic fridge had a bad thermister but apparently I just don't know how to operate it. It used to freeze everything now it won't go below 45 degrees.
The temp control knob has a bunch of lines on it and I don't know what is the cold setting or the hot setting. There are lines like this on the knob and as you turn it one of the lines comes into the viewing window.
________
______
_____
____
__
_
So is the longest line on top the warm setting or is the shortest line on the bottom the warm setting???
Thanks for the help.
TARH2O
1975 25' Airstream TradeWind International - Under Renovation
2012 MB ML350 BlueTec
tarh2o is offline   Reply With Quote
Old 06-21-2015, 09:24 PM   #2
Jim&Teach
1976 31' Sovereign
Portage , Indiana
I hope you get a good answer because I just got a '76 31'LY. Lots of learning. This forum rocks!!!
jimmbob is offline   Reply With Quote
Old 06-21-2015, 11:13 PM   #3
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
Mine has numbers with 1 warmest and 9 coldest.
4RXLA is offline   Reply With Quote
Bowen water heater control knob LOREN SILVA Water Heaters, Filters & Pumps 0 11-13-2014 02:58 AM
Dual Heat Pump Temperature Control rperrym Furnaces, Heaters, Fireplaces & Air Conditioning 4 03-23-2014 09:24 PM
Shower Control Knob...? AIR-Quarius Sinks, Showers & Toilets 11 03-20-2009 11:07 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 08:54 AM
Wheel Hub Temperature 74Tradewind Axles 4 07-23-2002 07:26 PM
