08-06-2007, 06:31 AM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
super charge your fridge for less than 10 bucks!
hey all, in the neverending quest to keep my beer cold i came upon this idea.
instead of using a fridge fan powered by d cell batteries i came upon an really cool fan ment for hard drives!
it was $1.98 buy it now on e bay, plus 5 dollar shipping from hong kong. with misc. hardware and connectors the whole thing costs about 9 bucks.
installation was easy, i used 4 common binder clips. i removed the handles and drilled a 1/8 hole through the back. screws are stainless with nylocks. after drilling i painted them silver to make it look pretty. the whole assembly simply pushes into place on the fins in the back.
wiring was easy, two wires spliced into the hot side of the fridge light circuit. (if you have a fridge without an interior light an external power source would be required, power could be routed through the cooling fin drain if needed.)
so far i am impressed with the performance, the fridge was cooling much quicker, i had about 30 degrees in the upper fridge section after 2 hours!
hopefully, i will have cold beer and no more frozen lettuce!
john
you call them ferrets, i call them weasels.
08-06-2007, 06:51 AM
1984 29' Sovereign
Savannah
, Missouri
Suggestion:
Throw out the lettuce and, you'll have room for more beer~!
Make mine a Guinness..
WBCCI 5292 AIR 807
NEU #64
New England Unit
08-06-2007, 07:42 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
those power supply and processor fans work well and draw litte power. i've used the power supply fan during summer black outs to keep me cool at home. a fantastic fan might speed that cooling even more ;-)
08-06-2007, 08:19 AM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
you are correct they don't draw much current, .36 amps. less than the 15 watt fridge light.
here are the specs on the fan:
Specification - Reduce hard drive temperature
- Extends your hard disk drive life and reliability
- Fits 3 1/2" hard drive
- Easy Installation
- MT BF-sleeve 20000 hrs. ball-40000hrs
- Air Flow-36 CFM(1 unit)
- Speed -4000rpm(1 unit)
- Static Pressure-0.09 INCH-HO
- Voltage-12V DC
- Power-4.32W
- Curenct-0.36A
- Dimension-130x103X16mm(LxWxH)
- 3.5" Hard Disk Drive Cooler
- Weight: 92g
john
08-06-2007, 08:22 AM
2007 27' International CCD FB
Everett
The fan installation looks great!!! What happened to the other two beers???
08-06-2007, 08:23 AM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
i had to have something to drink while i was wiring it in!
john
08-06-2007, 08:40 AM
Tramp Streamer
1995 28' Excella
Artist
, at Large
Cool
John!
Thanks for the cool guide, much better than my boxter fan zipped tied to the fridge shelf!
Michael
08-06-2007, 08:58 AM
2005 19' Safari
1968 24' Tradewind
Rural
, Delaware
I applaud your ingenuity, and raise my glass to your motive.
I've been looking at those computer fans to replace the noisy one that cools the reefer compartment. As soon as I find out the CFM of the original fan, I'll try to match it with a quieter fan, maybe one with those cool blue LED lights.
Google Image Result for http://cool-cases-usa.com/Zen-Cart-v1.2.4/images/lt120bl.bmp
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
08-06-2007, 01:18 PM
1999 34' Excella
Joshua
This also works.
History doesn't repeat itself, people do!
08-06-2007, 01:20 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
nice install dwight, is the thumb switch to turn it on/off?
might add one to mine.
john
