Old 08-06-2007, 06:31 AM   #1
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
super charge your fridge for less than 10 bucks!
hey all, in the neverending quest to keep my beer cold i came upon this idea.
instead of using a fridge fan powered by d cell batteries i came upon an really cool fan ment for hard drives!
it was $1.98 buy it now on e bay, plus 5 dollar shipping from hong kong. with misc. hardware and connectors the whole thing costs about 9 bucks.
installation was easy, i used 4 common binder clips. i removed the handles and drilled a 1/8 hole through the back. screws are stainless with nylocks. after drilling i painted them silver to make it look pretty. the whole assembly simply pushes into place on the fins in the back.
wiring was easy, two wires spliced into the hot side of the fridge light circuit. (if you have a fridge without an interior light an external power source would be required, power could be routed through the cooling fin drain if needed.)
so far i am impressed with the performance, the fridge was cooling much quicker, i had about 30 degrees in the upper fridge section after 2 hours!
hopefully, i will have cold beer and no more frozen lettuce!
john
Name:	frige fan inside.jpg
you call them ferrets, i call them weasels.
Old 08-06-2007, 06:51 AM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Suggestion:
Throw out the lettuce and, you'll have room for more beer~!
Make mine a Guinness..
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is online now   Reply With Quote
Old 08-06-2007, 07:42 AM   #3
richinny's Avatar
2011 34' Classic
those power supply and processor fans work well and draw litte power. i've used the power supply fan during summer black outs to keep me cool at home. a fantastic fan might speed that cooling even more ;-)
Old 08-06-2007, 08:19 AM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
you are correct they don't draw much current, .36 amps. less than the 15 watt fridge light.
here are the specs on the fan:
Specification
  • Reduce hard drive temperature
  • Extends your hard disk drive life and reliability
  • Fits 3 1/2" hard drive
  • Easy Installation
  • MT BF-sleeve 20000 hrs. ball-40000hrs
  • Air Flow-36 CFM(1 unit)
  • Speed -4000rpm(1 unit)
  • Static Pressure-0.09 INCH-HO
  • Voltage-12V DC
  • Power-4.32W
  • Curenct-0.36A
  • Dimension-130x103X16mm(LxWxH)
  • 3.5" Hard Disk Drive Cooler
  • Weight: 92g
john
Old 08-06-2007, 08:22 AM   #5
HankandLois's Avatar
2007 27' International CCD FB
Everett , Washington
The fan installation looks great!!! What happened to the other two beers???
HankandLois is offline   Reply With Quote
Old 08-06-2007, 08:22 AM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
btw, this is the outfit i got it from, ignore the price and look it up on ebay.
Computer PC HDD 2 Fan 3.5" Hard Drive Cooler Blower Exhaust--Silver
john
Old 08-06-2007, 08:23 AM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i had to have something to drink while i was wiring it in!
john
Old 08-06-2007, 08:40 AM   #8
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Cool
John!
Thanks for the cool guide, much better than my boxter fan zipped tied to the fridge shelf!
Michael
ArtStream is offline   Reply With Quote
Old 08-06-2007, 08:58 AM   #9
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
I applaud your ingenuity, and raise my glass to your motive.
I've been looking at those computer fans to replace the noisy one that cools the reefer compartment. As soon as I find out the CFM of the original fan, I'll try to match it with a quieter fan, maybe one with those cool blue LED lights.
Google Image Result for http://cool-cases-usa.com/Zen-Cart-v1.2.4/images/lt120bl.bmp
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 08-06-2007, 10:51 AM   #10
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Thumbs up Great Idea
Thanks for the idea. I have one on the way now. I had to get a blue one to match the exterior trim on my Excella.
I also ordered a 120mm fan for a low draw personal fan:
Y65 120mm Standard PC/Mac System Case Cooling Fan - (item 120148977930 end time Aug-09-07 09:15:00 PDT)
Compter fans make great 12v fans. Quiet and low power required.
Vaughan
Old 08-06-2007, 01:18 PM   #11
Dwight's Avatar
1999 34' Excella
Joshua , Texas
This also works.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 08-06-2007, 01:20 PM   #12
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
nice install dwight, is the thumb switch to turn it on/off?
might add one to mine.
john
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
Charge Wizard - Help! dmreilly10000 Electrical - Systems, Generators, Batteries & Solar 6 11-15-2002 03:37 PM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 06:34 PM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 05:49 AM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 06:44 AM
