Old 09-06-2005, 08:11 PM   #1
Austin , Central Texas
Stumped by the Frig
My frig runs fine on A/C (frig 36-40 degrees 15 - 20 degrees). However, on gas, the frig warms but the freezer holds cold. On 12v, nothing.
I am most concerned that the gas doesn't give me the more efficient cooling capacity. My dealer said replace the unit. I don't seem this is necessary as the unit runs fine on A/C power.
I am confused to the situation. Please advise.
FlyFishInn is offline   Reply With Quote
Old 09-06-2005, 08:16 PM   #2
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Rivet Check it out ...
Try wandering around this site: http://www.rvmobile.com
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 09-06-2005, 09:00 PM   #3
Firecop's Avatar
1978 31' Excella 500
Woodland , Utah
Fridge problems
I had a similar problem, only I did not get any cooling on gas. Problem was, it plugged up by rust/debris in the burner. Cleaned everything out and now it works great. The 12V issue may be the heating element has gone south. I am not sure if those 3 -way fridges have a 12V heating element or not. I don't have 12V on mine as it is a very old one. Try a search and see what you come up with. There is a lot of info on this site, it just takes time and patience to find it.
LOL Kim
Firecop
Firecop is offline   Reply With Quote
Old 09-06-2005, 09:38 PM   #4
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
My trailer is at the dealers at the moment because it is doing just what you describe. There could be any of a number of causes; some are:
  • Low gas pressure
  • Clogged up burner
  • Gas thermostat not working
  • High flame solenoid not working
  • Circuit board problem
Most models have a separate thermostat for gas and electric operation.
As for the 12v failure; sounds like a burned out 12v heater element. They are relatively easy to remove and replace. In 12v operation, there are no thermostats or circuitry involved. The 12v is simply turned on and left on since it is not powerful enough to cause freezing problems. That is why the element is the most suspect.
In my case, it appears to be the citrcuit board staying in low-flame mode since AC operation cools well enough to freeze food in the refrigerator section at the coldest setting.
John W. Irwin
WBCCI #9632
Old 09-06-2005, 11:48 PM   #5
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Just thought I'd put in my .02 . I just put my refer back in after restoring. It only went to 52 deg the first time around. So I did some research and found that for optimum operation you need good venting. I also found that my burner was a bit clogged. I cleaned the thermostat, cleaned the burner, and adjusted the flame. Now it ranges from 38 to 50 in the main compartment. I still have venting issues to tackle. Not too bad for a 40 yr old fridge. Mine is gas only and original to my '65 Caravel. Once I get the venting fixed ( I have a dead air space on top of the refer ) I expect it to work just fine.
Chris
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
frig and a/c suggestions Neenm General Appliance Topics 6 04-08-2007 07:42 PM
Pilot light in Frig niftypkg Refrigerators 9 04-10-2005 12:04 PM
stumped todd Airstream Trailer Forums 4 04-21-2004 12:20 PM
Frig replacement.... Silver Bullet Refrigerators 1 12-19-2002 10:10 PM
Rust on Frig. niftypkg Refrigerators 0 05-20-2002 06:43 PM
