Old 05-10-2006, 04:49 PM   #1
draftwomyn21's Avatar
1966 26' Overlander
Phoenix , Arizona
Send a message via Yahoo to draftwomyn21
Striker Rod for '66 Overlander
Hi All,
I'm on the hunt for a striker rod for my refridgerator pilot. I have a spot for one, the manual says I should have one, BUT the slot is empty. This means I have to light my fridg. from the outside with someone holding the red button from the inside .
Does anyone have any idea where I might locate one of these?
Thanks Bunches,
Robin out
"Courage is the hallmark of the warrior"
draftwomyn21 is offline   Reply With Quote
Old 05-10-2006, 07:09 PM   #2
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
BULLS GAP , Tennessee
I am guessing that you have a Dometic Fridge. If you tell the model , someone may be able to help you.
Old 05-10-2006, 07:14 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Robin, I will have to check my garage, I may have one for your fridge.
Old 05-10-2006, 08:17 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
One man job
You do not need someone inside to hold down the red button. Simply look at the control valve one time when someone pushes the button. It is a simple linkage that pushes up on a button on the control valve on the outside. You use one hand to hold up the button on the control valve while using a barbaque lighter to light the pilot. Then move down the trailer and light the water heater at the same time. Does not take longer than going inside to use the original spark lighter.
Old 05-18-2006, 08:53 PM   #5
Barkingdogg's Avatar
Newcastle , Oklahoma
Striker rod
Hi,
Dbaur ( Scholar ,gentleman, & airstream forum member) sent me the following:
Product #9283131 Dometic refrigerator striker rod & gas control valve thermostat, that he had removed from a Dometic frig in a 69 Globetrotter. It won't work on my refrig that is also missing the striker rod. My striker rod would fit in the interior of the frig & only be about 6 inches long. The one he sent is about 2 feet & looks like it would mount outside the box. The unit has a plate the themostat knob, pilot lite push button & striker are attached to. I can send a pic if need be. Does this sound like what you are looking for?
Barkingdogg
Barkingdogg is offline   Reply With Quote
Old 05-19-2006, 08:54 AM   #6
1966 26' Overlander
Phoenix , Arizona
Striker Rod
Hi Guy,
Yes, this sounds like what I am looking for, at least the length sounds right.
Would you be willing to part with it and if so for how much?
I appreciate the info. on how to complete a one-person light from outside, but I'd prefer to not have to do that (wind is an issue).
Let me know?
Robin out
Originally Posted by Barkingdogg
Hi,
Barkingdogg
Old 05-21-2006, 08:20 PM   #7
HI,
Dave Baur sent it to me at no charge & I'll do the same. Just let me know where to send it. If you can't use it pass it on.
Barkingdogg
First shower in my 1975 Overlander !!! pjtaia Our Community 14 07-05-2015 12:46 PM
1966 Overlander International Double Tamara 1965 - 1969 Overlander 30 03-28-2006 02:55 PM
Thinking of Buying '72 Overlander Joe C 1970 - 1973 Overlander 16 07-20-2005 06:01 AM
receptacle replacement 1960 overlander rod Electrical - Systems, Generators, Batteries & Solar 3 10-31-2002 07:19 AM
2-door Overlander InsideOut 1960 - 1964 Overlander 0 08-30-2002 08:14 AM
