Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 11-25-2011, 10:26 AM   #1
1976 29' Ambassador
Tarpon Springs , Florida
Sticky fridge seals
My newly acquired Airstream has old seals that have developed a sticky surface. Has anyone seen this before? Can I just clean them with a Goo B Gone or something and move on or who they need replacing?
Hopichangi is offline   Reply With Quote
Old 11-25-2011, 10:52 AM   #2
Clean them and then spray them with "silicone spray".
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-25-2011, 11:10 PM   #3
1976 29' Ambassador
Thanks. May all my Airstream woes be resolved so easily.
Old 11-26-2011, 01:08 AM   #4
Rutherfordton , North Carolina
Sometimes you can get away with spraying just a bit of WD40 on a rag and it will clean and "de-sticky" the seal.
Yodaforce is offline   Reply With Quote
Old 11-26-2011, 04:51 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The sticky is caused by the same thing the sticky is caused by on the walls of the 70's trailers. Some of the seals are flexible PVC and and can be fixed the same way. By cleaning it off and putting a coating on it to prevent re-emergence.
Old 11-27-2011, 01:38 AM   #6
Elf1's Avatar
1990 34' Limited
Proud to be , an American
Also try Krud Cutter ( Home Depot) cleans as well ;-)
Elf1 is offline   Reply With Quote
Old 11-27-2011, 05:40 AM   #7
1969 27' Overlander
Albuquerque , New Mexico
Cleaning with peanut butter...
Peanut butter is very gentle on old plastic. The peanut oil breaks down a lot of organic gums, including chewing gum and label adhesive. You have to wash it off with soap and water afterwards, of course.
Andy,
you might know the answer to this, regarding the fridge seals: I want to change the swing direction of the Dometic fridge from left hand to right hand. When I swapped the hinge sides, the door won't properly close because the seals are "sticking".
Can the seals be replaced, or softened up to re-seat properly?
Ed Glenn
edglenn is offline   Reply With Quote
Old 11-27-2011, 07:58 AM   #8
1977 31' Sovereign
1989 34' Excella
Do not use peanut butter. The peanut oil in it will act as a plasticizer and permeate into the seal and soften it, but the Peanut oil will go rancid and also drive out more plasticizer. You will end up with a smelly sticky seal. The original plasticizer was likely DOP and an oxidized soy bean oil. If you need to soften the gasket use DOP.
Old 11-28-2011, 08:11 PM   #9
1969 27' Overlander
That's good information....
What's "DOP"?
Ed Glenn
Old 11-28-2011, 08:57 PM   #10
1977 31' Sovereign
1989 34' Excella
Di Octal Phalate. also sometimes called DEHP by some. It is the most common plasticizer used in PVC, also the cheapest. I used to buy it by the ton. I have not investigated where you could buy it by the bottle.
Old 11-29-2011, 07:01 AM   #11
1981 31' Excella II
New Market , Alabama
You could replace the seal.
McMaster-Carr
Perry
Old 11-29-2011, 11:04 AM   #12
1969 27' Overlander
I'm afraid to ask. How hard IS it to replace fridge seals?
Ed Glenn
Old 11-29-2011, 11:10 AM   #13
1981 31' Excella II
Do it and let us know. I am not sure how they attach. Most attach with sheet metal screws under the lip. Should be pretty easy.
Perry
Old 11-29-2011, 03:52 PM   #14
1969 27' Overlander
Famous last words; "Should be pretty easy."
Right up there with "Look Ma, no hands!!!"
Ed Glenn
Need help on installing Dometic RM100 fridge door seals carol4266 Refrigerators 3 03-24-2017 10:21 AM
Clipper, Dometic Refrigerator, Fridge Lamp Switch masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 01-05-2013 11:14 AM
Fridge Sorta Kinda Works perryg114 Refrigerators 17 10-23-2011 07:46 PM
New fridge on the Outs? skydiva Refrigerators 2 07-04-2011 03:04 PM
