Old 12-14-2007, 09:22 AM   #1
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
Slipping Fridge Panel
The aluminum panel covering our Dometic fridge keeps slipping down into its bottom channel, exposing the rought top edge of the panel. Anyone have this problem? And if so, what was your solution?
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 12-14-2007, 10:55 AM   #2
westernviews's Avatar
2013 27' Flying Cloud
Livingston , Texas
I had this happen on mine. The dealer service tech was able to easily snap it back in place with the black trim piece that holds it in place.
Westernviews.us
westernviews is offline   Reply With Quote
Old 12-14-2007, 11:18 AM   #3
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
The insert panel is designed to be 1/8" thick, the aluminum panel may be too thin, a bit of double face tape on the back may keep it from slipping.
Greg
Greg@AirLA is offline   Reply With Quote
Fridge door panel replacement... how to? pamelake Refrigerators 13 05-17-2015 03:12 PM
12V panel dmadam Electrical - Systems, Generators, Batteries & Solar 4 03-02-2007 06:24 AM
Panel or not Over59 Ribs, Skins & Rivets 6 10-07-2004 12:20 PM
6.0 cu. ft. Refrigerator Panel Sandy H Refrigerators 6 08-10-2004 12:01 PM
