Old 04-04-2004, 01:45 PM   #1
aviontt's Avatar
, Connecticut
Size Does Matter...
Replacing my fridge and I was wondering if anyone has replaced theirs with an electric only I have the small fridge in my 1975 Argosy and want to replace it with an electric model Just wondering if anyone has a brand name and a size ? for this replacement
Worry will never change the outcome!!!
aviontt is offline   Reply With Quote
Old 04-04-2004, 02:41 PM   #2
Rubyacht's Avatar
Images: 14
my solution....
may not work for you or most people but I removed the refer (electric) that had been installed in the place of the original and installed an under the counter small electric one. When I'm dry camping I place a frozen container of water to keep things cold. I suppose dry ice would work too. I have a chest freezer available to me in the area to keep a string of replacement bottles of ice so I was able to use my refer as a large cooler all last summer. If I occassionally moved into the campground I'd plug into 110v. I found it a little bit of a hassle but only lost some tortillas to mold once so the bottles of ice worked were fine. The old old refers had a drain in the bottom of them that piped outside so blocks of ice could be used when boomdocking.
Niki
Rubyacht is offline   Reply With Quote
Old 04-21-2004, 03:14 PM   #3
imeynstein's Avatar
Texarkana , Arkansas
refridgerator
I had asked this question recently and found out that this was not a problem at all. We went to Lowe's and found an efficiency sized refridgerator to replace our old Dometic fridge. When removing your fridge, you will notice a plug in from your previous fridge and it plugs right in. I can't recall the measurements, but the fridge will run right at $300 bucks. Also Home Depot carries them, but you have to order them.
imeynstein
imeynstein is offline   Reply With Quote
Old 04-21-2004, 05:11 PM   #4
aviontt's Avatar
, Connecticut
Note: The fridge I have is under the counter...Small one
Old 04-21-2004, 07:20 PM   #5
77 R GO C MH's Avatar
1977 28' Argosy 28
Lincoln , Nebraska
I have an electric only replacement frig in my MH. I looked into replacing it with an original type but they started around $1100. I figured I'd keep what I had (since it works great) and could but alot of gas for my generator for the big difference in cost.
77 R GO C MH is offline   Reply With Quote
Old 02-27-2005, 12:45 AM   #6
I have found a place that sells BRAND NEW Dometic and Norcold fridges for about half of what they cost elsewhere. I also bought a new stove/oven and a water pump from these people at about half the price of retail.
Send me a Pivate Message and I will share this information with you. It seems that I have a problem posting new threads on here.
Lou
Anon is offline   Reply With Quote
awning polycord size sovereign Awnings 5 04-23-2012 12:38 PM
what size rivet? Tin Hut Ribs, Skins & Rivets 3 10-03-2003 08:20 AM
20í MH Tire size? Don B Airstream Motorhome Forums 7 09-29-2003 07:45 AM
Gas bottle size skipj Our Community 4 06-30-2003 07:11 PM
tire size? goodgrey Tires 8 01-06-2003 09:27 PM
