Old 04-09-2019, 05:37 PM   #1
1976 Argosy 28
calgary , Alberta
RV vs Domestic fridge
I am looking to replace the fridge in my '72 with a newer model and have been seeing different people using domestic propane/2 way fridges in their rv's. I have also read that the domestic ones will not hold up to all the vibrations and bumps they will get while towing. Any feed back?
alberta paso is offline   Reply With Quote
Old 04-09-2019, 05:45 PM   #2
2013 20' Flying Cloud
Westerly , Rhode Island
How would you vent it? On electric it will still make heat, on propane heat and combustion fumes.
smithcreek is offline   Reply With Quote
Old 04-09-2019, 05:48 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Huh, that must be a local thing. Generally when I see a non-RV fridge in an Airstream it's the cheapest thing Wal-Mart sells (Haier etc.) and it's an electric-only dorm fridge.
Some people actually beef up their batteries a bit and run the dorm fridges off batteries w/ an inverter when traveling and only stay where there's power, and they say it works for them.
Home 2-way propane fridges aren't all THAT much cheaper than RV fridges. A 6 cubic ft "Unique" brand propane fridge is about $1k, a 6-cu-ft Dometic RV fridge is about $1.2k
David
domestic fridge problem nightowlhooter1 Refrigerators 7 05-11-2016 10:25 AM
1962 Gas Domestic Fridge not cooling. jwhenke Refrigerators 8 03-03-2014 02:46 PM
Can I repaint the inside of my vintage Domestic fridge? LucyPepper Refrigerators 4 10-03-2010 06:28 PM
'62 LP Domestic Fridge jrsygrl Refrigerators 0 01-18-2010 07:07 PM
