Old 08-11-2010, 07:53 PM   #1
2006 25' Safari
Buffalo Grove , Illinois
running the refrigerator when towing
Our Refrigerator does not work when we are pulling, should I be using the gas option or what, advise!!!
Airhaus on the road fulltime in Nov. 2010
airhaus is offline   Reply With Quote
Old 08-11-2010, 07:57 PM   #2
x
XXXX , XXXX
Yes you should use the gas mode when on the road unless you have a n extremely long extension cord. LOL
wasagachris is offline   Reply With Quote
Old 08-11-2010, 07:59 PM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
There are different modes for fridges. Some are two-way, generally meaning either propane or 110 volt. In the latter case, this means being plugged in somewhere (shore power, generator). Others are three-way: propane, 110 volt or 12 volt. I'm not sure how North American three-ways work, but on our European Dometic three-way, the 12 volt must come from the tow vehicle, not from the RV.
Many modern units require a smidgen of 12-volt electricity to operate on propane. (It's just to operate the control system, not to participate directly in cooling.) Note that this 12 volt supply can come from the RV.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 08-11-2010, 08:04 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
In our 2006 19' Bambi we set it on "Auto" which means that when the frig detects 110 current it is on 110 and when you unplug or turn your generator off it switches automatically to propane. You have the option to override the 110 and use propane at any point. I presume your 2006 would have a similar set up even if your fridge is large than that in a Bambi.
Again, presuming that your battery charged, if you have it set on Auto and it is not switching automatically or not cooling on propane while towing, something is amiss and you should have it checked.
TB & Greg and Abbey Schnauzer
#3954
Old 08-11-2010, 08:18 PM   #5
_
this thread should probably be moved to the fridge SUB forum...
where u will find this question regularly addressed.
and the debate about blowing UP at fuel/filling station stops.
http://www.airforums.com/forums/f425...ing-53710.html
http://www.airforums.com/forums/f160...ling-2015.html
http://www.airforums.com/forums/f425...ion-55123.html
http://www.airforums.com/forums/f368...ing-35706.html
http://www.airforums.com/forums/f425...tion-9704.html
http://www.airforums.com/forums/f160...wing-6802.html
there is even an OLD POLL on the topic...
http://www.airforums.com/forums/f232...ling-7780.html
it is surprising 2me that nearly 1 n 3 do NOT run the fridge in route.
and there are those that promote turning it OFF while traveling and using ice...
that would NOT be cool imo.
cheers
2air'
Old 08-11-2010, 08:19 PM   #6
x
XXXX , XXXX
I was just joking around before. The auto mode for your fridge will be as described in the earlier post. You must leave your propane tanks turned on and have a good battery to run the 12 VDC circuit board in the fridge. When you unplug from shore power do you still have 12 VDC lighting. Your tow vehicle may be equipped with a charge circuit line to recharge the trailer battery when in tow. A simple way to check is to turn on all the lights in the trailer and if they get brighter when you plug in to your tow vehicle and the motor is running then it is equipped. Please advise if you have 12 VDC w/o shore power and if T/V has charge circuit and I will try to help. Also does the fridge try to light on propane and fail and go into lockout mode.
Old 08-11-2010, 08:58 PM   #7
aftermath's Avatar
Spokane , Washington
To answer your question, YES put it on the Gas mode. I also have a 2006 Safari and the options are, automatic or gas. If you choose automatic, it will run on electricity when plugged in but "automatically" change over to gas when you unhook. I run mine on gas all the time because it actually cools better than electricity.
If your fridge is working while plugged in but stops working when you are traveling, you might have another issue. Try running it on gas and see what happens.
aftermath is online now   Reply With Quote
Old 08-11-2010, 09:13 PM   #8
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Regardless of the naysayers, RV fridges are not well enough insulated to keep food safe over a day's towing in summer heat. I have an inside-outside wireless thermometer with the outside sender mounted in the fridge. Even with the fridge on propane, mine will creep up from the low 30s to about 45 to 47 during a summer travel day. My fridge does not blow out. I attribute the temperature creep to poor air circulation that starves the airflow over the fins. This seems to be common in 28' trailers.
Once when I forgot to switch the propane bottle, the inside temperature was in the high 50s when I caught it late in the day.
I just installed the Snyder fan kit that insures airflow over the fins. I'm curious to see whether the fridge will hold temperature better with forced airflow.
John W. Irwin
WBCCI #9632
Newbie Towing Question...the ancronyms are running together!!! TINLOVE Tow Vehicles 4 05-24-2010 01:02 PM
Running the refrigerator with out propane tanks khaled Electrical - Systems, Generators, Batteries & Solar 22 12-09-2008 05:41 PM
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
Refrigerator Fan won't stop running tsunami Refrigerators 18 09-17-2007 01:50 PM
Running the fridge while towing? andyfuson General Motorhome Topics 15 09-20-2003 12:15 AM
