Old 08-10-2015, 09:47 AM   #29
2015 27' FB International
mesquite , Texas
Question
are you suppose to shut off the propane tank if it is running the fridge while traveling down the hgw. And you pull in to fuel your tow vehicle?
Appears to be a good safety issue, but this is the first ive heard of it.
moxie t. moto is offline   Reply With Quote
Old 08-10-2015, 11:44 AM   #30
aftermath's Avatar
Spokane , Washington
No need to turn off the propane at the tank. Those who choose to shut down the fridge when refueling simply turn the fridge off. When off, there is no pilot light and no chance of a flame coming on. Once you drive away from the pumps you can pull over and turn the fridge back on and be on your way.
aftermath is offline   Reply With Quote
Old 08-10-2015, 01:03 PM   #31
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I think it's simply a simple case of a little common sense going a long way!
Yes pumping gas on a pilot light will result in an explosion, keeping a safe distance most likely will not!
Buyer beware!
Old 08-10-2015, 01:12 PM   #32
2002 22' International
Corvallis , Oregon
Running refer using invertot
I run my Airstream (Dometic) on 110vac using an invertor. The propane is not on while traveling.
300 watt investor powering refer circuit only, using a separate dedicated 12 vdc cord to the invertor. 10 gauge wire from TV batteries through a receptacle on rear bumper. Total cost for 2 relays 30' of wire and investor about $300.
boblind is offline   Reply With Quote
Old 08-10-2015, 06:14 PM   #33
1967 26' Overlander
Spartanburg , South Carolina
Our '67 has an opening directly under the flame for the reefer which is approx 15' from the TV gas fill. That distance is probably enough to dissipate fumes from fill up, but my great fear is a spill which could run under the trailer and foom! I stop and turn the gas off before driving to the pump.
Jacob D is offline   Reply With Quote
Old 08-10-2015, 06:55 PM   #34
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
In the past on our other trailers we ran with the propane on . When pulling in for gas I would check the wind direction and stay up wind of the pumps on the outside island.
If that wasn't an option I would shut off the refer.
Now on our Tradewind I only have 120v & 12v available at this time . I haven't installed the propane system yet.
So on the last 2 trips I ran 12v while on the road the refer worked great and the Tundra kept the battery up. We've covered over 2500 miles so far.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 08-10-2015, 07:28 PM   #35
The Cralls
thecralls's Avatar
2012 28' International
Bremerton , Washington
I have stood next to the refer and opened the door and watched the flame shut off, then turn on again. You can hear it if you are standing next to the refer, the igniter will make a noise when it re-lights. So I do know it works.
thecralls is offline   Reply With Quote
Old 08-11-2015, 09:01 PM   #36
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Originally Posted by m.hony View Post
They're all RV's.
Travel trailer is a type or category of RV- Recreational Vehicle-
Motor Home is another type or category of RV.
A fifth wheel is an RV.
A Class A motor home is an RV.
A Class B motor home is an RV.
A Class C motor home is an RV.
A travel trailer is an RV.
A pop-up trailer is an RV.
A teardrop trailer is an RV.
They're all RV's.
RV doesn't just mean motor home.
Thanks so much Mr. Hony. I'm going to write all that down, so I don't screw up that RV thing ever again.
Howard L. is offline   Reply With Quote
Old 08-12-2015, 05:57 AM   #37
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by howard l. View Post
thanks so much mr. Hony. I'm going to write all that down, so i don't screw up that rv thing ever again.
Sent from my ipad using airstream forums
lmao😜
MICHAEL
Frig 110 Volt running on invertor on the road? airdreamers Electrical - Systems, Generators, Batteries & Solar 8 07-03-2014 06:46 AM
Running refrigerator on the road ILOVESALLY Airstream Trailer Forums 6 12-26-2013 10:00 AM
On the road running light help... livinlightly Lights - Interior & Exterior 0 12-02-2012 08:20 PM
Refer not cooling on the road crios Refrigerators 6 07-17-2011 11:05 AM
Refer Won't Stay Running on LP wbcci3371 Refrigerators 3 05-20-2004 12:14 AM
