Old 08-12-2019, 12:36 PM   #1
2017 16' Sport
Canyon Country , California
Unhappy Rotten Meat Smell in Fridge
ok now I camped in the NTM Bambi twice but could not find the culprit for the rotten meat smell in the fridge. It has been cleaned out several times. I do not smell anything as long as the fridge door is completely closed but when it is open, it smells awful even when its cold.
What do I do?
2014 Ford Explorer XLT with factory installed Tow Package.
2017 M16 Bambi
Halford1 is offline   Reply With Quote
Old 08-12-2019, 01:22 PM   #2
2007 22' International CCD
Put either a box of baking soda in it with the door closed, or a 1/2 cup of fresh coffee grounds in it the same way. Let it sit for a week or so.
Also flush out the drain hose. Sometimes stuff gets into the line and gives off a stink.
Do you prop the door open when it’s in storage? Sometimes smells build up when the door is closed.
rmkrum is online now   Reply With Quote
Old 08-12-2019, 01:30 PM   #3
2017 16' Sport
I left the door open while in storage. I have a small bag of potpourri and baking soda bag as well. I guess I will work on the drainage tube.
2017 M16 Bambi
Old 08-12-2019, 02:09 PM   #4
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Check Outside as Well
After you clean out the drain tube,
open the outside access door and check to see if the same stench is present.
If so, or even if you are not quite sure check under the fridge with a flashlight. Use a mirror to really take a good look under it.
If you find a dead critter. Check for holes in the screen that covers the ventilation hole in the floor (if your model still has one.)
P.S. If you don't find and remove the source of the stench, no amount of baking soda and/or coffee will solve the problem.
Hope this helps.
Ken L
2019 Flying Cloud 27FB
2018 GMC Yukon Denali XL
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 08-12-2019, 06:21 PM   #5
ITSNO60's Avatar
Tucson , AZ
Are you sure you are not smelling propane?
Brian
ITSNO60 is online now   Reply With Quote
Old 08-12-2019, 07:39 PM   #6
Alumaholic's Avatar
Images: 36
Propane smells like rotten eggs, Halford1.
There is a critical difference.
ITSNO60 may be on to something.
Ken L
Old 08-12-2019, 07:44 PM   #7
mkcurtiss's Avatar
1968 26' Overlander
CORDOVA , TN
Fortunately, even a dead critter will eventually stop stinking.....
1968 Overlander Land Yacht International
Ford E-350 W V-10 booom!
2018 Chevy Tahoe smooooooth
Find a way to enjoy life and have fun, every day !
mkcurtiss is offline   Reply With Quote
Old 08-12-2019, 08:11 PM   #8
2017 16' Sport
Thank you... I am profound deaf myself.... my sense of smell, feeling and vision senses had increased to compensate for the loss of my hearing at age of two.
I KNOW what propane smells like. I grill (not BBQ) a lot BTW . Once i smelled a gas leak at home and had gas man come to find the leak, but the gas leak detector did not pick up the leaked gas so I had him to stay while I smelled around and eventually found the loose copper pipe fittings by hot water heater.
I will use my nose this week to find that damn source.
I remember seeing that white tube with screen at end of the tube. I will have to (sic) smell that or look around the fridge. I believe the source is concentrated inside because it only smells so bad the second I open the fridge. gonna need to get me a looooooong tube cleaner!
2017 M16 Bambi
Old 08-12-2019, 08:13 PM   #9
ITSNO60's Avatar
Tucson , AZ
Many years ago when I had a Lance truck camper we had returned from a fishing trip. The following week every time I went into the camper I smelled what I thought was dead, rotting worms. I was sure my buddy had left his worms in there somewhere but as I gradually emptied out the rig I couldn't find them. I finally realized that the oven was on pilot without being lit and it was propane I was smelling. Not sure why the propane was still on, that was a long, long time ago and I probably didn't know any better, or else there was still stuff in the fridge.
Brian
Old 08-12-2019, 08:18 PM   #10
2017 16' Sport
2nd reason why I am positively, pretty sure that it is not the propane is because I shut it off.
2017 M16 Bambi
Old 08-13-2019, 05:01 AM   #11
brokeboater's Avatar
2003 25' Safari
High Springs , Florida
I once did a major boo boo and turned off the RV fridge, forgetting that the wife had used the freezer for some overflow storage. I was pretty sure I'd ruined the fridge as none of the usual solutions solved the rancid meat smell in the freezer. I've been unable to find my exact procedure so I'm going on memory. I tried this solution posted by a commercial refrigeration guy. I removed everything removable and soaked in a large tub of bleach/water. I poured bleach into the freezer compartment, about 1/2" deep, closed the freezer and let it sit for 24 hours. Obviously after 24 hours or so you clean the mess up. Seems like I had to do it twice to completely eliminate the smell. My recollection of his explanation was tiny food particles in nooks and crannies are the culprit and the concentrated chlorine permeates every nook and crannie eliminating the source of the odor. Try this or not at your own risk as I am going by memory and even if my memory is correct it may not be a brilliant idea. But after much scrubbing, much baking soda, coffee, ammonia, you name it, the bleach soak finally solved the issue. I still use that fridge on a daily basis and no longer get that rude reminder of my mistake. Only your story brought back the not so pleasant memories.
“While you live, shine / Have no grief at all / Life exists only for a short while / And time demands its toll.”
brokeboater is offline   Reply With Quote
Old 08-13-2019, 05:37 AM   #12
2004 28' Classic
Roebling , New Jersey
I’ve found that weed eater string makes a great snake for this type of cleaning tasks. I’ve used it in clogged fuel lines and rain gutter drains on my car. Cheap and chances are you or your neighbor has a spool laying around to use.
Your fridge drain line is a perfect candidate for this approach.
Dad250 is offline   Reply With Quote
Old 08-13-2019, 06:55 AM   #13
Gainesville , Florida
To the op, maybe the original owner left the fridge closed with food in it and the power off. If so it might not be fixable.
Old 08-13-2019, 07:14 AM   #14
Kevin245's Avatar
We used a mix of hot water and baking soda to defunk our fridge when we experienced an unattended shutdown. It required a few treatments followed by rinsing each time. We applied the mixture with a pump up sprayer, then left the fridge closed to steam things loose. Then we rinsed with high pressure cold water and wet vacuumed the effluent.
Eleanor Roosevelt
Kevin245 is online now   Reply With Quote
Fresh Meat Crambi Member Introductions 2 03-23-2017 01:17 PM
Meat and Beans pappy19 Stella's Kitchen 2 01-08-2016 01:58 PM
Spring Meat and Fire Rally, Northern Illinois till Forum Rallies & Meet Ups 52 08-12-2012 09:43 PM
Rotten egg / sulfur smell niss1679 Electrical - Systems, Generators, Batteries & Solar 17 10-17-2005 06:08 PM
