Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 05-28-2008, 09:07 PM   #1
Profile:  1973 23' Safari
Red Lion , Pennsylvania
RM60 Dometic Refrigerator
Hello everybody! Could anyone tell me where I could purchase a thermostat for a Dometic RM60 model refrigerator. It is from a 23ft 1973 Safari.I would apreciate any info, I also would consider buying used if anybody has one that wants to sell.
Thanks, Rudy in Pennsylvania
Argentum is offline   Reply With Quote
Old 05-28-2008, 09:13 PM   #2
bobfowler's Avatar
Profile:  1972 Argosy 20
2007 Base Camp
Middletown , New Jersey
Images: 14
What seems to be the problem with the fridge? Does it work OK on 120V and not gas, or just not work at all?
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
bobfowler is offline   Reply With Quote
Old 05-28-2008, 09:50 PM   #3
Thanks for your answer. Yes it works on LP and I checked the stat with a ohm meter and it is open, so I jumped the terminals and it works fine, so the electric thermostat is bad.
Old 05-28-2008, 11:17 PM   #4
My Grandparents Airstream
Andrew Selking's Avatar
Profile:  2007 25' Safari FB SE
Fort Worth , Texas
Send a message via AIM to Andrew Selking
Send LEWSTER a pm he is a great help on the Dometic products.
Andrew Selking
WBCCI #6062 VAC
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 05-28-2008, 11:25 PM   #5
bobfowler's Avatar
2007 Base Camp
Images: 14
You beat me to it...
Bob Fowler
Old 05-29-2008, 09:37 PM   #6
Thanks guys, sorry I did not answer sooner I was tied up doing house remodeling, I would contact LEWSTER soon. Thanks again... Rudy
Old 05-29-2008, 09:57 PM   #7
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
LOOKING FOR ME ???????????????
Lew Farber -Certified Master RV Tech (currently on Forums sabbatical)
WBCCI #1032/VAC (assoc) #1032 AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 09-16-2008, 01:16 PM   #8
Profile:  1974 27' Overlander
Placerville , California
Lewster I was looking at this and I have a similar problem. I did not see any answer to the original. Where can I get a thermostat for the Dometic refer. My problem appears to be in the LP side. No matter where I have it set the flame does not change and it freezes in the refer portion. Any help would be appreciated.
ronsgto is offline   Reply With Quote
Old 09-16-2008, 04:29 PM   #9
Commercial Vendor
lewster's Avatar
Ron,
Sounds like your t/stat is frozen closed and is not letting the LP burner cycle as needed.....thus running wide open. I don't believe that Dometic supports the RM-60 any longer with service parts. You might try Out-of-doors mart (a forum member) or google RM-60 parts or old Dometic parts and see what comes up.
Old 09-16-2008, 05:51 PM   #10
Thanks very much I did just one problem which maybe the whole problem. The dial was broken internaly thus when I though I had it on 2 or 3 it was probably set much higher. I managed to use the dial for the electric and turn it down. I will keep an eye on it. I will see if I can get a new dial through Out of Doors mart or maybe there is a bone yard some where.
Old 09-18-2008, 07:57 AM   #11
Ronsgto: I was able to find a tstat at:
PPL's RV Parts Superstore
10777 Southwest Freeway (Hwy 59 South)
Houston, Tx 77074-9829
1-800-755-4775
Mine was the electric tstat, I believe it cost me around 35.00 and they have both gas and electric, since they are located in Houston I don't know if they are back in operation after the hurricane, give it a try, also they have a catalog on the web, go thru Goggle you will see it there. Good luck, if they don't have it, I have to look but I think I have another supplier on my favorites.
Rudy (Argentum)
Old 09-18-2008, 08:12 AM   #12
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Try Snyders Refridgeration, somewhere in PA. Also there are a couple of places in Elkhart that have a lot of new old stock parts. I don't recall specific contact info, but I know it has been previously mentioned in posts. You should find Snyders on the internet. But hopfully a forums member has the contacts and will post it to this thread.
Pay no attention to the man behind the curtain- WoZ
Dometic Refrigerator CarlGeo Refrigerators 10 10-01-2007 09:19 PM
Dometic Refrigerator CarlGeo Airstream Motorhome Forums 2 08-31-2007 07:30 PM
I fixed it x2 (NOT) HELP Dometic RM60 Lumatic Refrigerators 25 07-31-2007 04:39 PM
HELP!! Bought new Dometic refrigerator--How do I remove the rm60? Shelby Copeland Refrigerators 5 01-15-2006 11:17 PM
Dometic Refrigerator scotta Airstream Motorhome Forums 1 03-16-2003 10:57 AM
