Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 09-02-2009, 01:35 PM   #1
Profile:  1976 31' Sovereign
Moncks Corner , South Carolina
RM100 trips break as soon as I trun it on
The tiltle says it all. The very second I turn the power on it trips the breaker. Can someone help me?
Norm1234 is offline   Reply With Quote
Old 09-02-2009, 04:50 PM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
First suggestion is to unplug the fridge from the outlet and check for a short. Try turning the a.c. switch to off, and see if the beaker still trips. If it does, the problem is between the switch and the plug. If it doesn't, the short is between the switch and the heating element. It could be the heating element itself, or could be a mouse chewed through some insulation.
(No Longer at Inland RV)
Old 09-02-2009, 05:59 PM   #3
It is in the refrigerator. If I unplug it the refigerator the breaker stops triping. Is there a circuit board that could be back in the old beast or just a heat element.
Old 09-02-2009, 06:35 PM   #4
Well-Preserved
It should have two thermostats, one for LP and one for electric, with a "LP/Elec" knob. The knob turns a gas valve on and off, and moves the toggle switch. I'd check the switch, they do sometimes go bad, and make sure none of the wires have been chewed or are frayed. There really should be no circuit board, other than possibly the electronic igniter, which is independent ot the other wiring.
Old 09-02-2009, 08:18 PM   #5
Thanks for the info. I will check it out this weekend.
Old 09-08-2009, 06:07 PM   #6
OK, the gas part of the refrigerators it working fine. how do I tell if the switch or the heating element it bad? All wiring looks to be in good shape.
Old 09-08-2009, 07:38 PM   #7
Profile:  1977 31' Excella 500
1967 30' Sovereign
plano , Texas
Mine was tripping the breaker when I first got it, but since then I cleaned the contact blocks and everything has been running fine for 4 years. The RM 100 was the standard fridge for the 77 and 78 excella 500 and you can find the service and owners manual and service manual online at:
1978 Airstream Excella 500 Manuals
-thomas
tschat is offline   Reply With Quote
Old 09-13-2009, 12:42 PM   #8
Ok, I cleaned the the wires going to the refrigator and its not tripping the breaker anymore. I have 121.9 volt going to the heating element. However the heating element is not warming up. I pulled the wires off the the board and took a reading and I can't get a ohm reading from it(open circuit). Does this mean the heating element it bad.
Old 09-13-2009, 02:29 PM   #9
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
Depends on where you are measuring.
The heating element from one side to the other should be 2 to 5 ohms.
No reading indicates an open circuit (bad heater coil).
What happens many times the heater coil will break and one side starts touching ground popping the breaker. I'm just wondering if you did anything to move the heater coil thus removing the short or are you measuring directly across the coils. Something happed to clear the short and stop tripping the breaker.
Garry
garry is online now   Reply With Quote
Old 09-13-2009, 04:32 PM   #10
Yep it is reading open now. I think im going to try a new element. I will post how it works when I get it in. thanks for the reply.
2009 Road Trips CrawfordGene On The Road... 339 11-23-2009 03:59 PM
Cookbooks for your road trips fonseca Stella's Kitchen 46 10-28-2007 12:16 PM
photos of our summer trips gotair Off Topic Forum 6 09-05-2005 06:25 AM
Best size for Trips Over59 On The Road... 0 03-15-2004 07:29 PM
First Trips COLORADO_CAMPER 1999 - 2004 Bambi 5 07-18-2003 11:42 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
