Old 04-15-2003, 03:54 PM   #1
JohnGalt48's Avatar
1977 31' Sovereign
RM100 flue cleaning?
I've got a '77 Sovereign with the original RM100 fridge in it. It sorta works, but sometimes it takes a day or two to really get cold. I've got the service manual for the trailer, and it talks about cleaning the flue regularly, but doesn't really show or explain exactly how to do it. I know it hasn't been done in the 5 years that I've owned it, and who knows before that.
Is there anyone who can describe in simple terms, exactly how to clean the flue? Maybe someone has some pictures posted somewhere? Any other maintenance suggestions would be welcome too....
JG
JohnGalt48 is offline   Reply With Quote
Old 06-17-2003, 08:14 PM   #2
Robert L. Cornute's Avatar
Smile RM 100 Cleaning of the flue
It will take some doing; you will need a selection of brass brushes and a vacume cleaner; use the brass to clean the rust scales from the iron coil in the back of the refer. this will all fall down onto the bottom of the compartment; use the vacume cleaner to pick-up the debris and to reach hard to clean areas of the compartment. Good Luck, I just finished cleaning mine two days ago. Bob Cornute, 77 soverign International 31' Rear Bath and twin bed's 1997 Ram 2500 Van tow vehicle.(360 FI V-8)
Robert L. Cornute is offline   Reply With Quote
Old 06-28-2003, 02:17 PM   #3
flue cleaning
I got the burner going and the frezzer is getting cold, now here is the big question. How do you clean the flue? is the unit pulled out from the wall? I looked everywhere for the flue, all I can find is the houseing in the upper cabinet and no way to get into it.
Gene Wissink is offline   Reply With Quote
Old 06-28-2003, 04:20 PM   #4
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Robert;
After going through all that, can you see an actual difference in before and after the cleaning.
-BobbyW
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
carb cleaning George Mechanics Corner - Engines, Transmission & More... 7 09-01-2003 07:55 PM
RM100 flue cleaning? JohnGalt48 Refrigerators 0 04-15-2003 05:38 AM
replacing RM100 refrigerator... JohnGalt48 Refrigerators 5 12-23-2002 04:52 AM
Cleaning a 41 year old AlumiTank? Andy R Fresh Water Systems 1 05-21-2002 06:54 PM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
