| changing refer in a 75 sovereign
I just pulled my old one out. The new one ((exact replacement)) Ha! the new one is just a little smaller, the door panels don't match. You need a 12 volt suppply to run it. I pulled it from the 12 socket next to the old one. The ref won't fit the hole it is smaller.. save all the wood for spacers. Takes about 3 hours to do it. The new ref is really worth the effort though.. keeps the bottom at 33% and the top at 5%. Just right for ice cream..... works best on the gas cycle at the highest setting. Default setting is on electric... Kase you gas runs out...
You need a helper to get the other one out.. drill and rivets are necessary. also the insulation around the bottom needs to be beefed up..
My RV is really "down by the Delaware
river" Frenchtown, NJ
