Hello,
We woke up this morning to a strong odor of ammonia inside our fridge. I was able to quickly find the cause (leaking evaporator coil) but a solution is proving a bit more challenging. This would be a 2 way LP/electric unit. Trailer is a 1969 Land Yacht Ambassador Double, fridge is original to the coach.
Initially I wanted to install a new or refurbished cooling unit (512 A1). These don't appear to be readily available. Please advise if you have a lead on a reputable supplier.
Now I'm looking into retrofitting with a modern fridge. According to the original refrigerator's manual, it measures H: 59.5" x W: 23.25" x D: 22.375". The closest I've found in overall size from Dometic is the RM3762 and DM2662 which measure 1.5" deeper, 0.4375" wider and a several inches shorter. Measuring from the exterior access panel I'm seeing 5.75" clearance from the rear of the refer "frame" to the interior edge of the access panel, and 2.5" from the burner/heater cover to the access panel with the original unit.
I can live with the face of the fridge protruding an inch+ from the cabinet, the gap up top and I think I can wiggle in the <1/4" in each side width wise. I'll need to supply
12v to the control module for LP operation which I'm guessing will require a new DC wire run. I'm not particular to the Dometic brand, it's just where I looked first. If you happen to know of a brand and model that is any closer in dimension to the original I'd happily consider it.
Can anyone lend any insight to any other problems I may encounter? Is there anything I'm disregarding? We're full-timing so a functional fridge is important to us.
Thanks very much for any help!
Tim
