Old 04-23-2010, 06:34 PM   #1
my1ststream's Avatar
1963 24' Tradewind
St Louis , Missouri
Replacement parts for '63 Dometic fridge....
Hi everyone.
Went to run my fridge in my '63 Tradewind, and got the the pilot lit. While holding the pilot button to heat the Klixon, a small flame shot out near my finger and slightly toasted my fingertip. After the initial freekout, I checked for leaks, found none, and restarted the pilot. Held the pilot button in with a pencil, and waited at least a minute, but the pilot went out after I released the button. Not easily deterred, I lit the pilot again(pushing the button with a pencil and watching for the errant flame to return....it didn't) and waited a good long couple of minutes for the Klixon to heat up. as I lay prone on the floor of the camper, I looked away from the polit light to relieve the fatigue in my neck, and when I looked back at the pilot flame. I noticed that my Klixon had melted! So obviously my thermocouplethingy is in need of replacement, along with a Klixon thingy. I looked around the interweb to no avail for the parts. Any feedback on a repair solution? The fridge is definitly worth repairing.
Thanks!
my1ststream is offline   Reply With Quote
Old 04-23-2010, 06:49 PM   #2
Baltimore , Maryland
straight up... you have an obsolete item. As cool as they are you will find no one to be able to work on it. Please prove me wrong, for I am still storing my 1962 Dometic in hopes of fixing it someday.
My 18th call lead to a guy saying "stop wasting your time and pick out a new fridge."
Old 04-23-2010, 06:56 PM   #3
1963 24' Tradewind
St Louis , Missouri
Yeah, that's what I'm getting fom all the pros.
I may just put a modern pilot and burner assembly in it, if I can find it before the Rend lake rally. I think I'll be using the "five day cooler" while I save up for a fridge tho......
Old 04-23-2010, 07:05 PM   #4
I pursued that option too. You will strike out on the retro fitting a new burner also.
Not trying to rain on your parade, I have just come to grips with the reality of not having my B50 any longer.
Old 04-23-2010, 07:10 PM   #5
1963 24' Tradewind
St Louis , Missouri
what was the problem with the retrofit?
Old 04-23-2010, 07:36 PM   #6
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
My 59 fridge (not sure of the model #) still works & i've fiddled with it & others quite a bit & learned a lot over the past 9 years, so i am familiar with your dilema. Everything is servicable if you're creative enough. I had a client some years ago with a 62 GT with the original fridge. It had a burner on it that was somewhat newer than the fridge. It worked fine but the installation was very crude & unsafe. Oddly enough I had a dead fridge from a 63 TW with a good burner so i installed it for him & it's still running fine today. Bottom line, it is possible to install an updated burner in those "cool" old fridges.
Colin
Colin H is offline   Reply With Quote
Old 04-23-2010, 08:19 PM   #7
1963 24' Tradewind
St Louis , Missouri
Colin;
I definitly think a retrofit would be worth doing research on. I think the newer burners and parts are mainly refined and more efficient versions of the origional. My goal is simply to heat an ammonia mixture to produce refrigeration. I guess I'll start with that pilot and burner assembly.
Thanks.
Old 04-24-2010, 06:24 AM   #8
Well there ya have. Colin says it can be done, so I say go for it...
Old 04-24-2010, 08:07 AM   #9
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Dometic Service Manual
Don't know if this will help in any way but I got this service manual last year when I tried to resurrect the Fridge on my 72. There are parts out there and people who rebuild the cores. Wound up replacing with a new Dometic that is slightly larger in size with less space inside. Had to rebuild the counter/cabinet to make it fit.
RichHog is offline   Reply With Quote
Old 04-24-2010, 08:39 AM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Can you post some pics of what you have? I just completed repairing the Dometic in my '74 Argosy. Did not have too much trouble finding parts. What is the model # of your fridge. Is the Klixon the piezo electric device to light the pilot? Do you light it from the front of the fridge or the back?
Old 04-27-2010, 07:06 AM   #11
1963 24' Tradewind
St Louis , Missouri
Twinkie;
My frige is the old dometic that has a goofy metallic toungue that serves as a polit control. I'm talkin old.
Old 04-27-2010, 07:59 AM   #12
Modifying any LPG system, takes on a huge liability.
Accordingly, a good dealer won't touch that stuff, and many times will refuse to sell parts for the modifications.
Old 04-27-2010, 08:15 AM   #13
1977 Argosy 24
Milltown , Wisconsin
We have a 1969 Mallard camper with a still working Dometec fridge with the old Klixon burner. I see no reason why it could not be retrofitted with a newer burner and gas control system as long as the ammonia cooling system is still intact. In fact I bet you could put the 110 volt electric heater in the chimney or replace the entire chimney with the electric heater from a newer Dometec unit.
ventport is offline   Reply With Quote
Old 04-28-2010, 07:01 AM   #14
1963 24' Tradewind
St Louis , Missouri
Andy,
As a fellow company man, I understand the liabilty. Being a hands on guy and wanting to be safe(family in the camper, and all that), This idea will go thru quite a bit of research, and testing. Heck, I plan on taking it out and attatching to a tank out in the feild of dreams to test it properly without fear of property damage.
But then again, if it is deemed too radical or unsafe, I'll just get a new one.
? on dometic fridge twiggy137 Refrigerators 11 05-23-2008 05:58 AM
68 Dometic Fridge bmongiello Refrigerators 3 05-30-2006 12:31 PM
Dometic Fridge angie@smartw Refrigerators 3 08-03-2005 09:57 AM
1970 23' Safari - Dometic Fridge Replacement JayRay Refrigerators 1 07-19-2004 10:44 PM
