Old 04-28-2010, 07:06 AM   #15
my1ststream's Avatar
1963 24' Tradewind
St Louis , Missouri
Originally Posted by ventport View Post
We have a 1969 Mallard camper with a still working Dometec fridge with the old Klixon burner. I see no reason why it could not be retrofitted with a newer burner and gas control system as long as the ammonia cooling system is still intact. In fact I bet you could put the 110 volt electric heater in the chimney or replace the entire chimney with the electric heater from a newer Dometec unit.
VP;
You are followimg my train of thoght on this one. The key would be flame control for maintaing the proper temp to move the ammonia solution at the proper rate.
Lemme take some notes on the modern controls to see what they are spec'ed to.
my1ststream is offline   Reply With Quote
Old 04-28-2010, 08:22 AM   #16
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
Dometic Service Manual
Here is a copy of a Dometic Service Manual for older Dometics, which should include your model. I know finding a Klicon Safety Valve that works for these models is very difficult. I have found only 1 out 4 that I purchased used that worked. Working old burners are a little easier to find. If you could find modern burners & safety valves to work on these older Dometics, we would all benefit. Good Luck
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 04-28-2010, 10:04 AM   #17
Originally Posted by my1ststream View Post
Andy,
As a fellow company man, I understand the liabilty. Being a hands on guy and wanting to be safe(family in the camper, and all that), This idea will go thru quite a bit of research, and testing. Heck, I plan on taking it out and attatching to a tank out in the feild of dreams to test it properly without fear of property damage.
But then again, if it is deemed too radical or unsafe, I'll just get a new one.
Bench testing is great.
But, and that's a huge "BUT" will you also test it for the vibration and pounding it gets, when installed in the trailer?
That's when the liability kicks in, should it fail.
If a customer buys a exact replacement part, and messes up the installation, then they buy the farm.
If a customer buys a "should work" or a "substitute" part that was spced by the dealer, then the dealer buys the farm.
Personally, I have no need to by "any" farm.
Old 04-28-2010, 04:48 PM   #18
Images: 30
Klixon safety valve & burner
Would all of this need to be replaced?
Old 04-28-2010, 05:29 PM   #19
1963 24' Tradewind
San Diego , California
I have a "63" TW with the og refer. propane only. The ceramic piece at the pilot light was broken, along with other issues. I found a trailer repairman in the area who had the parts I needed.. Also the og water heater parts as well. I will try to find his ph# when i get home today and post it. He has many parts. He is known here as "The Old Fart With The Old Part" Worth a try!
Sixty3TW4US is offline   Reply With Quote
Old 04-28-2010, 07:05 PM   #20
1963 24' Tradewind
I found the ph# to the person I purchased all my og water heater and refer parts. His name is Leonard 619-449-6231 the last time I talked to him was 1.5yrs ago Good luck
Old 04-29-2010, 06:05 AM   #21
1963 24' Tradewind
St Louis , Missouri
Andy,
It's like you can read my thoughts from Cali! get outta my head, man!!!
On a serious note, I am listining to the words of caution. You gotta nice fridge out in the warehouse that will work? I would LOVE to run a fridge off of my solar panel/battery combo!
Old 04-29-2010, 06:21 AM   #22
1963 24' Tradewind
St Louis , Missouri
Thumbs up
Not all parts need to be replaced, as of yet....
Got a polot cotrol valve, and a new thermocouple. The origional two port pilot needle attached directly to the new pilot vave.
These were OTC parts from the local HVAC house. As it turns out, the klixon melted because the pilot light was sett to high, and well, it was simply old. Will try connecting it all and testing it after I get a few spare parts to do fitment tests on.
***This is just a quick update, I am NO WHERE near answering all my/your questions on this effort. ***
Thanks for all the info, from both sides of the agument.
Brian
Old 04-29-2010, 07:06 AM   #23
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
The Dometic fridge in my 60 has a retrofited burner and control. It's really not very complicated. All it needs is heat up the tube and a control mounted strongly to the base of the fridge. Mine has worked for a few years now with no problems. It's a little overrated as turned up I can make the fridge into a freezer.
I know that a dealer can't do this kind of thing, and I won't do it for you but it's mine and I know it's good.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 04-30-2010, 08:39 AM   #24
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
It still amazes me how you can heat something up and it makes something cold. Tries all of the tricks on my 72 Dometic and couldn't unclog the system so I upgraded. How many people have a 38 year old fridge still in their houses?
RichHog is offline   Reply With Quote
Old 05-06-2010, 04:23 PM   #25
1963 24' Tradewind
St Louis , Missouri
Actually, I have a 60's fridgidare at the house....works perfect....and it's pink....
Old 05-07-2010, 07:25 AM   #26
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Well they don't make them like that anymore
Old 05-10-2010, 05:45 AM   #27
1963 24' Tradewind
St Louis , Missouri
Funny update:
Pulled out old Heater with the assistance of the Soldier Medic, and guess what I discovered?
All the parts and connections are interchangeable, Hopefully allowing me to keep the old ceramic burner....
I'll start takin pictures....
Old 05-12-2010, 07:18 AM   #28
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Soldermedic helped me install my new furnace in my 72 on a very cold Texas afternoon at the Vinage Rally in lake Conroe. Great guy to have in your neighborhood.
? on dometic fridge twiggy137 Refrigerators 11 05-23-2008 05:58 AM
68 Dometic Fridge bmongiello Refrigerators 3 05-30-2006 12:31 PM
Dometic Fridge angie@smartw Refrigerators 3 08-03-2005 09:57 AM
1970 23' Safari - Dometic Fridge Replacement JayRay Refrigerators 1 07-19-2004 10:44 PM
