Old 06-04-2010, 07:22 AM   #1
1978 31' Excella 500
SOUTH ANHERST , Ohio
Replacement of a dometic refrigerator
Question i am new to the air steam traveling, never doing this before , i have just purchased a 1975 argosy and will be doing a little remodle , it has real good bones but needs a little up dateing .
I now have a working dometic refrigerator that works fine and i am going to replace it , can one use any small store purchased one or must it be makd for a trailer ?? And thoughts on the issue
thanks george
Gosman is offline   Reply With Quote
Old 06-04-2010, 08:36 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If it works?
Store bought refers need to be plugged into 120 volt AC. So you would have to run a generator or be plugged into shore power in order for it to work. If you plan to travel long distances it would be hard to keep the contents cold while in route. Why do you want to replace a working refer?
Old 06-05-2010, 06:53 AM   #3
replacement
Just purchased the trailer and was thinking of replaceing my dometic refrigerator with something newer and a bit smaller to build a counter top , to fit over the new one that would be smaller.
Question though being new to the camping world , how does this dometic refrigerator work? a/c power or what. I have the trailer parked and pluged in to the home and as we speak the refrigerator is running , should I shut it of were we are not going any were and if so how is that done??.
It is not running of the battery in the trailer by doing this , is it ?
I thought I read some were one has to light some thing to turn it on .?? Sorry for so many questions , but as they say no question is a dum one!!!!!! I AM NEW TO THE CAMPING WORLD OF AIR STREAMS
Thanks So Much
George
Old 06-05-2010, 07:11 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
A refrigerator from the 70's runs on either propane or 120 volts electric. It works by heating ammonia which is sealed in a cooling unit on the back of the refrigerator. There should be a series of knobs inside the unit which control which mode it is running in and also control the temperature. The switch for the mode it is running in also has an "off" position. There is also a hold lever and a spark button to ignite the flame when the unit is running in propane mode.
These are great units and give you the ability to camp when you are off the grid.
Richard
Old 06-05-2010, 07:25 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I have a '74 Argosy. Probably the same refer you have. There are instructions for operating the unit inside the door on the lower shelf. There is a knob that has three positions. "Gas" "Off" "Electric" . If you haven't made any attempt to lite the small burner that runs off propane and the refer is cooling, then the switch is in the "Electric" mode. In the electric mode there is a small (150 watt) heating element that runs off shore power (power from your house).
It is important to note that for the refer to operate correctly, the trailer needs to be within a half a bubble of being level. You must have it pretty close to level if it is cooling.
If you need more info or help with it. I'll be happy to post photo's etc.
Good Luck!
Old 06-05-2010, 10:34 AM   #6
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Dometic Refr
Here is a manual I collected before having to dump my old dometic for a new one. Hope it helps
RichHog is offline   Reply With Quote
Old 06-06-2010, 06:54 AM   #7
THANK YOU ALL FOR ALL YOUR HELP AND RICHHOG FOR TH MANUAL AND TG TWINKL FOR THE INFORMATION ALSO TG TWINKL IF THE OFFER FOR PHOTO S IS STILL OPEN PLEASE POST THIM .
I HAVE IT RUNNING ON Electric AT THE PRESENT TIME AND IT IS COOLING JUST FINE SO I GUESS IT IS LEVEL? THE LAST OWNER HAS NEVER TRIED TO LIGHT THE BURNER AND HAVE IT RUN OFF PROPANE, I AM NOT EVEN SURE IF THAT WORKS ?.
ALSO ANOTHER QUESTION , SEEING THAT I WILL BE WORKING ON THE TRAILER FOR THE REST OF THE YEAR AND NOT TRAVELING , SHOULD I UNPLUG THE POWER AND DISCONNECT THE BATTRIES , BECAUSE WHIN I UNPLUG THE POWER FROM MY HOME IT GOS TO THE BATTRIES AND I DO NOT WANT TO RUN THIM DOWN .
( SHOULD I HAVE ONE OR TWO BATTRIES , I BELIEVE I ONLY HAVE ONE .
SORRY FOR SO MANY QUESTION , I AM SO NEW TO THE AIRSTREAM FAMILY .
THANK YOU ALL SO MUCH FOR YOUR KIND HELP
GEORGE
Old 06-07-2010, 10:44 AM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Refer Controls
Here is the Photo. Hope it helps. If you need more help let us know.
Old 06-07-2010, 10:52 AM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Batteries
If you are going to work in the trailer you will need power and lights. All original lighting is 12 volt. Mine works just fine leaving it plugged into shore power. So far I have not cooked the battery and it's been plugged in for 8 months. I have a Triad-Utrad TU-331 converter, I believe it is original equipment. I have not run "Off the Grid" so I don't know how long the battery will last.
Old 06-08-2010, 08:06 AM   #10
TG TWINKIE
ALSO IF I MAY DO YOU LEAVE THE refrigerator on all the time .It is set for electric at the present time . When not traveling do you leave pluged in to your home ?
I guess the question I am asking ,if I have no power turned on from my home will the refrigerator still run off the batterys . And in order to shut the unit down I would have to disconnect the battery ,as to not have any power to the unit at all ??
I did see in your photo GAS OFF but did not see electric off?
Thank you so much for your photos.
Sorry for asking so many questions , very new to the traveler tralier community and just do not want to wear out the refrigerator .
Thanks So Much George
Old 06-08-2010, 08:50 AM   #11
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by Gosman View Post
TG TWINKIE
When not connected to AC power, you must run off gas. Even the newer ones that have a 12 volt DC choice will only run a short time befor depleting the charge in the battery(ies). The older refrigerators that require you to manually choose between gas or electric and light the gas burner do not have any connection to the 12 volt system. Plus and minus kind of thing. While the newer ones will automatically detect which to use, they place a small drain on the battery and will not work at all if there is no 12v power to their logic board. While easier to use when you have 12v power, it can be nice to have something that works entirely without electricity.
As far at the GAS OFF switch goes, it is a three way switch. One way GAS, another ELECTRIC, and finally OFF. Off means completely off, not running on either.
Vaughan
Old 06-08-2010, 08:53 AM   #12
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Your fridge should run on Gas/propane or 120V Electric but not on batteries. The newer Dometics have a 12V version but the old ones don't. Wouldn't run it if you don't plan to use it even if the trailer is plugged in. Make sure that after you use it on a trip you leave the door open for about a day or so to let the moisture all dry out so you don't get mildew inside.
Think Vaughan said it well above.
Old 06-08-2010, 09:16 AM   #13
1983 34' Excella
1967 24' Tradewind
Images: 32
One tip a friend swears by to help with the mildew and odor issues is to stuff the fridge with wadded-up old newspapers when not in use. I haven't tried it, but it's worth considering.
Thanks!
Vaughan
Old 06-08-2010, 11:32 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Mold and Mildew
I leave the door ajar when the refer is not in use. Keeps it fresh. You only have 2 choices Gas or Electric. That is 120 volt AC only, no battery. The switch for GAS OFF ELECTRIC has three positions. It rotates with off in the center. Turn it Clockwise from the OFF position it should say Gas, turn it counterclockwise from the OFF position it should say Electric. I would recommend turning it OFF if you are not using it to keep things cold. The electric heating element has a finite life span, like a light bulb.
Dometic Refrigerator FlyFishInn Refrigerators 27 09-22-2014 10:39 AM
Dometic Refrigerator CarlGeo Airstream Motorhome Forums 8 09-16-2010 08:19 PM
Dometic Refrigerator CarlGeo Refrigerators 10 10-01-2007 08:19 PM
Dometic refrigerator wiring walter1 Electrical - Systems, Generators, Batteries & Solar 2 09-07-2004 01:21 PM
Dometic Refrigerator scotta Airstream Motorhome Forums 1 03-16-2003 09:57 AM
