Old 09-03-2004, 09:22 PM   #1
Wagon Master
Replacement Fridge
I am tossing the orig. Dometic on my 68GT. It still works but the freezer door is missing. I am getting a new dometic to put back in. Now the question is: Am I going to have to gut one of those crappy, cheep and ugly plastic door on the outside or will the hole with the mesh on the floor under the onld one be enough for the venting ( scoop still on the wall too)
Thanks, Igor
Igor68 is offline   Reply With Quote
Old 09-04-2004, 05:36 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Replacement Fridge
Greetings Igor!
Thanks, Igor
My Airstream dealer installed a new Dometic 3-Way RV refrigerfator in my '64 Overlander in 1999. There were no modifications to the exterior of the coach and only minor modifications to the cabinetry to achieve the proper fit of the new refrigerator. Thus far, I have had absolutely no performance problems with the unit. I rarely use the LP feature as I don't like LP appliances, but it has operated flawlessly on 12-volt DC as well as 120-volt AC.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
1970 23' Safari - Dometic Fridge Replacement JayRay Refrigerators 1 07-19-2004 10:44 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
Let's start with the Fridge.... GT1963 Refrigerators 6 03-03-2004 09:01 PM
Fridge replacement/ Inverter needs rdm General Motorhome Topics 4 01-20-2004 06:04 PM
Carpet Replacement with wood Roger and Nancy Floor Finishes 32 12-07-2003 11:06 AM
