Old 06-15-2015, 10:59 AM   #1
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Repaired Fridge Scoop and Fridge insides
So, I have a 64 Overlander. The PO used duct tape to repair cracks in the white plastic interior of my fridge. It works. I'm replacing the old crank flint lighter with a new pietzo push button lighter. Anyway, on the plastic door, pulled it out, gently pulled away the old duct tape, and then cleaned - laboriously the duct tape glue. Acetone, goo gone, and several other cleaners would melt the plastic, but Alcohol seemed to work fine, it just took forever. Then, I stretched plastic tape on the face side to close the cracks up. I then flipped it over and used all purpose PVC cement on the back side. That repaired the cracks. Then I used aluminum 2 part tape all along the back to reinforce it for the future, the flipped it back over, and removed the clear tape from the front. No more cracks. there were a couple little spots where I did some airbrushing (light paiting) of gloss white, plastic bonding paint. But, basically as good as new.
The scoop was a different story. Unwaxed Polyester fiberglass will bond to ABS if you clean it really well with Acetone. This cleans, and roughs up the surface. I used self adhesive drywall fiberglass. That allowed a very thin profile, and it allowed me to wrap the edges. It unwrapped a little, but I used Reynolds release wrap as a "clamp". Fold over a few times, then pinch to the edge. That allowed it to clamp the fiberglass and it comes off immediately. All I have to do now is sand and airbrush the edge to look like the original zolatone.
ID:	240723   Click image for larger version
robwok is offline   Reply With Quote
Old 06-15-2015, 04:19 PM   #2
1979 23' Safari
Wayland , New York
I like the self stick fiberglass drywall tape idea. I'll have to use that on mine.
Old 08-19-2015, 11:01 AM   #3
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Almost done.
I was able to fake the zolatone with some really creative spray painting with my HVLP sprayer. The walls are darker because they haven't been cleaned yet, but I had a covered panel from the ceiling I was able to use to get exact color matches.
Old 08-19-2015, 11:20 AM   #4
batman's Avatar
1964 22' Safari
modesto , California
Really nice!
batman is offline   Reply With Quote
Old 08-25-2015, 09:04 AM   #5
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Updated pic installed.
I tried all kinds of things to clean the zolatone. Finally tried TSP and it worked like magic with very little scrubbing at all. Basically i just gently wipe, rinse, and repeat, then dry.
You can see the scoop is a pretty good match. I don't know why the pic came out fuzzy, just low light I think.
Old 08-25-2015, 09:05 AM   #6
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
I just cleaned the door and a strip along the ceiling to see how it would do. Really happy with it. It's a lot of work to keep it original!
Old 08-25-2015, 07:11 PM   #7
batman's Avatar
1964 22' Safari
Yes it sure is. I like the way yours turned out, very much.
Mine was toast. Broken,cracked and repaired with tape. So I elected to fabricate one that matches The cabinets I built. Maple and motor turned aluminum.
-Dennis
Old 08-26-2015, 05:43 AM   #8
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Oh that's nice Dennis. I have a whole cabinet shop and all kinds of experience I didn't get to use this time. Really like your mod.
Old 08-27-2015, 08:00 AM   #9
Ottawa , ON
Rob, Dennis: Excellent work, both of you. Thanks for showing us the possible!
Removing the fridge vent scoop Marcello3 Interior Restoration Forum 6 01-13-2015 02:29 PM
Replacing the Refrigerator and scoop funhouse 1965 Caravel 8 06-14-2014 07:12 PM
Any idea as to what type of plastic was used on reefer scoop and wheel wells? sarasafari Interior Restoration Forum 26 04-30-2013 08:14 AM
'67 Fridge Scoop Repair Dingo Girl Refrigerators 2 09-19-2011 07:47 PM
What are insides of trailer worth? 68vtsafari Dollars & Cents 7 11-02-2009 08:26 PM
