Old 10-12-2015, 08:30 PM   #1
1985 27' Sovereign
mckinney , Texas
Removing Fridge '85 Sovereign
Just started working on gutting the AS; got some help from some good people from Parker Texas who volunteered to start me of. (Thanks so much Jim and Wife; I owe you guys. I will be forever grateful to them).
I now need direction on removing the Norcold Fridge.
The electric and gas lines have been unplugged from the back. Not sure what next.
Are there any rivets I need to remove?
Is it screwed or bolted to the floor somewhere?
I am still not able to upload pics here. so here is a link to the pics in photobucket. I unscrewed 2 screws as u can see on the pic. and that was all I could find.
Fridge by mkamanu | Photobucket
Thanks in advance.
Miriam
mkamanu is offline   Reply With Quote
Old 11-09-2015, 10:45 PM   #2
nickclifford's Avatar
1972 31' Sovereign
felton , California
Tip on uploading pics, I discovered how easy the iPhone app is to use !
Much easier than the website for uploading pics.
nickclifford is offline   Reply With Quote
Old 11-10-2015, 04:38 AM   #3
2000 30' Excella
Toledo , Ohio
If it's anything like a Dometic there should be 2 screws in the rear at the base and 2 at the front at the base and 2 at the top front . I made a 2x4 frame stand to slide mine out on to when i removed my old one they weigh around 100 lbs. It's a tight fit in the opening you may need to give it a good push to get it moving .
woodfox45 is offline   Reply With Quote
Old 11-10-2015, 04:40 AM   #4
2000 30' Excella
Toledo , Ohio
forget about the stand I just looked at your pictures .
sovereign
Removing interior vinyl panels: rivet-removing tool? What's underneath? Ellie25ftSov Upholstery, Blinds, Walls & Interior Finishes 2 08-20-2014 08:34 PM
Removing Old Fridge Fletch8918 Refrigerators 2 11-09-2010 05:51 PM
Removing the fridge... deepsea27 Refrigerators 2 04-05-2010 05:44 AM
removing fridge and oven mark silberl Refrigerators 2 11-15-2006 12:47 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
