I find the usual RV refrigerators a bit stuffy/dorky looking. Are there alternative styles or at least doors and hinges to jazz the look up a bit? Craig Dorsey's
(Airstream Dreams) newest project appears to have a rather fine looking frig unit in it - I'll try to run that down as well but was wondering if anyone on the forum has any info.
Jo Ann
I have a GE "apartment style" in my Airstream. It only runs on 120V though. So far it has worked great for us. When boondocking we have ice in it and use an Honda generator to keep it going. If you keep your fridge full it holds cold better than if it is half full.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
WBCCI 1350
most of the fridges built in the last twenty years have replaceable front door panels that slide out if you remove one of the trim pieces. you can replace them with any decorating idea that you choose that will slide back into the trim pieces.
roger
havin' to fix my broken Airstreams since 1987... AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter Former Airstreams: 1953 Flying Cloud, 1957 Overlander, 1961 Bambi, 1970 Safari Special, 1978 Argosy Minuet, 1985 325 Moho, 1994 Limited 34' Two-door, 1994 B190 "B-Van"
