Old 09-05-2007, 11:19 PM   #1
2008 25' Safari SS SE
Longview , Washington
Refrigerator won't start
When my refrigerator is supposed to be running on propane, it will not start. There is plenty of propane in the tanks, and there does not appear to be any air in the lines because I can run the burners on the stove without any flickering of the burners. I can hear the igniter intermittently firing several times, then stopping for several minutes before restarting. I looked behind the fridge and there is a grey wire which is not attached to anything, and when the igniter is going off, it will spark if in close contact to metal. It sounds like there is also an igniter going off close to where I assume the propane intake is located. The trailer is a 2005 safari LS 22 footer. Thanks for any help you can offer.
msmst25 is offline   Reply With Quote
Old 09-06-2007, 05:00 AM   #2
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
We've got a 2005 and the same thing happened - the fridge needed a new control panel. It required a trip to the dealer, but it was covered under warranty. They replaced it and it works fine now - hopefully your dealer (or a qualified Dometic dealer) is not too far away.
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 09-06-2007, 05:14 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Check to make sure the cutoff valve hasn't lost a wire, it needs both to close the contacts, and open the valve. That could be where your grey wire goes. Also, check to see if the valve is getting power and ground, so it can open. If everything is hooked up, and it isn't working, you should probably take it to a place of repair.
Where do I start bertro Electrical - Systems, Generators, Batteries & Solar 4 12-03-2006 09:07 PM
How do I start refrigerator on propane popeyedoyle1 Refrigerators 6 02-21-2006 07:54 PM
a/c won't start Chipster Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-01-2005 09:57 AM
Where do we start? Rat Pack Interior Restoration Forum 2 01-11-2005 06:46 PM
where to start Phaedrus General Interior Topics 18 05-07-2003 03:56 PM
