Old 10-25-2015, 09:35 PM   #1
camper collector
Americus , Georgia
Refrigerator won't run on gas
I have a Servel model S 630
3-way refg and can't get it to lite on the LP gas side. I did as the owner manual instructed but the pilot lite won't lite. The elec igniter does not function Is there a way to short circuit the process or some way to lite it by bypassing the igniter? Any suggestions??
camper is offline   Reply With Quote
Old 10-26-2015, 04:57 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I am not familiar with this model but there may be a way to light the pilot light with a long handle lighter with the burner control in the pilot position. Once the pilot is lit give a minute or so to warm up the thermocouple and then switch the control to the on position.
Lumatic is online now   Reply With Quote
Old 10-27-2015, 06:11 AM   #3
camper collector
Americus , Georgia
It is an automatic so you have to set the DC selector on and set to GAS then it should lite.
Old 10-27-2015, 06:16 AM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
Has this fridge worked on gas for you then quit? Is there a dedicated in line propane valve somewhere for the fridge?
Old 10-27-2015, 10:58 AM   #5
Rocker66's Avatar
1965 24' Tradewind
Henderson , Nevada
Mine did the same thing until I figured out that it NEEDS a full 12 VOLT's to start the ignition for the gas. Make sure your batteries are charged and connected properly in the back of the fridge. I had a low battery but my lights and fans worked , I never thought it would have been the 12 volt but it was. Once I plugged into shore power and got the volts back up to 12, I heard the clicking noise and it started
Rocker66 is offline   Reply With Quote
Refrigerator won't light on gas jetjocky LP Gas, Piping, Tanks & Regulators 10 07-04-2014 11:12 AM
Refrigerator issue.. won't run when switched to LP ? Focusfactor1 General Repair Forum 6 07-25-2013 09:18 AM
Refrig Won't Run On Gas SteveH Refrigerators 4 03-30-2010 10:18 AM
Gas Refrigerator won't light Emh142 Refrigerators 11 07-07-2008 09:09 PM
