Old 06-19-2011, 06:58 AM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Refrigerator venting
Have new refrigerator that runs on propane, 12V, or electric. My question is, if I run it only on 12V or electric do I still need to run a vent to the outside?..................thanks
toastie is offline   Reply With Quote
Old 06-19-2011, 07:01 AM   #2
dznf0g's Avatar
Oswego , Illinois
Toastie, you still need to get the heat out from the rear of the fridge. Is that your question?
Old 06-19-2011, 07:04 AM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
You need to vent so convection will carry the heat away. You need vents under of behind the unit so the air will flow. I just installed a new Dometic in my TW and they are very clear in the instructions about the need for proper venting.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 06-19-2011, 07:16 AM   #4
toastie's Avatar
1955 22' Safari
yes, thanks
Old 06-19-2011, 07:58 AM   #5
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Originally Posted by toastie
yes, thanks
Will you ever run it on propane?
If not then wouldn't a Dan foss be better than absorption cycle system?
Darkspeed is offline   Reply With Quote
Old 06-19-2011, 09:10 AM   #6
toastie's Avatar
1955 22' Safari
probably not
Old 06-27-2011, 04:40 PM   #7
toastie's Avatar
1955 22' Safari
Will have a vent at the bottom per there instructions, but I still don't want to cut a hole in the side. Looking at going with a computer type fan that will force the warn air out the bottom vent. The fans are 12V and have a 300,000 hours life expectancy, any thoughts..................
Dynex™ - 80mm CPU Cooling Fan - DX-FAN101
toastie
