Old 12-25-2014, 11:31 AM   #1
1968 26' Overlander
West Richland , Washington
Refrigerator Vent thru the floor - '68 Overlander
I need advice on venting my refrigerator. I have completed replacing my floor and have a new refrigerator to install in the original location. My original refrigerator vented thru the roof with an intake thru the floor. It also has an access door thru the trailer wall at the back of the refrigerator.
My new refrigerator shows different methods of venting and I'm tempted to make the access door into a lower intake vent instead of cutting a hole thru the floor as it was originally installed. I'm asking advice on whether to cut a hole in the floor or not. Looks to me like the wall vent would work and I wouldn't have hole in the floor... Comments? suggestions?
JIMandPJ is offline   Reply With Quote
Old 12-25-2014, 11:55 AM   #2
1981 31' Excella II
New Market , Alabama
Getting a louvered door would be a good option in my opinion. There are some purists on here who would say no. If you already have an opening there why not us it. You can buy those doors at many of the Airstream online places like VTS, Outdoor Mart etc.
Perry
Old 12-25-2014, 12:19 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
My '67 Globetrotter and '72 Tradewind both have floor vents. Both fridges work well without additional fans sometimes found on side vented installations.
I wouldn't discount the idea of vents in the door as long as it has the same area. Additionally you have to sure the there won't be any water intrusion while parked or driving in rain.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 12-25-2014, 12:25 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Jim and PJ!
I think it is a question of personal preference. My 64 Over lander has the through the floor (and underbelly) while my 78 Minuet has a sidewall vent. My preference is the sleeker appearance of the Over lander, but each serve their intended purpose.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 12-25-2014, 12:37 PM   #5
DFlores's Avatar
1968 22' Safari
Call your local speed shop and find who they use for punching louvers, take two screws out that hold door together and remove outer skin and get hot rod louvers punched into outer piece. The inner aluminum piece can be drilled with 2" hole saw to create airflow. Well that is what I am doing for my 68.
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 12-26-2014, 10:38 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Don't most modern RV refrigerators vent through the wall? Some have a lower vent and an upper vent through the wall, others have a lower vent through the wall and a roof vent-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-27-2014, 11:48 PM   #7
1968 26' Overlander
My refrigerator installation manual allows for installation with a lower vent thru the wall or through the floor. I thought someone out there might have done some tests or something to demonstrate one method is better than the other. Currently I like louvers in the wall opening.
Old 12-28-2014, 06:13 AM   #8
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Because of their side wall curvature, the two side wall vents will have to be too close together, and too far away from the back of the fridge, for it to crate an effective draft. Many of the SOB trailers with two side vents also have a fan to force a draft on their fridges.
You could probably get away with a louvered side door, but don't cover the vent on the roof to add a vent on the side. No good will come from that.
Old 12-31-2014, 08:00 PM   #9
1968 26' Overlander
I'll use the existing roof vent and make the access door at the floor level into an intake vent.
Old 01-09-2015, 06:16 PM   #10
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Boy talk about timing and great minds thinking alike.
I've been planning for months to louver the compartment door for the refer instead of cutting the floor open after installing the new floor.
Well day before yesterday I found a guy and yesterday the louvers were punched.
Today I installed screen to the inside of the door and hot melt glued it in and here is the result in the next post.
ID:	230136   Click image for larger version
ID:	230138   Click image for larger version
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 01-09-2015, 06:17 PM   #11
Glenritas's Avatar
1969 25' Tradewind
These are 4" hot rod louvers 16 of them.
It should flow fine.
I left the inner shell with a lip to help stiffen the door and act as a splash catcher.
And the screen installation and final result.
I also flipped the door upside down so it would be out of the way when open just like I did all the other hatches on our '69 Tradewind .
ID:	230140   Click image for larger version
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
Old 01-12-2015, 09:25 PM   #12
1968 26' Overlander
Those look nice. My access door is about 12" hi by 15" wide. Haven't found anyone to punch them yet but I still plan on it.
Old 01-13-2015, 11:58 AM   #13
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
while you all are talking about this...my 66 has a hole inside the cabinet over the fridge. This has a cover inserted in it. I remove it to vent the warm air out. Is this typical on these old ones? It strikes me as weird as it vent the warm air into the cabinet... Or you have to leave the cabinet open.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-13-2015, 12:17 PM   #14
Tom Nugler's Avatar
1972 25' Tradewind
How big is the hole? As far as I know there should be a molded plastic duct riveted to the wall inside the cabinet extending up through the upper cabinet to the roof vent. Most are 20 inches wide and a couple deep.
Tom
AirForums # 2806
WBCCI / VAC # 6411
'75 Overlander - Need new vent vent covers Ultradog 1975 Overlander 8 07-21-2014 07:16 AM
2010 Int'l: Does cable coax go straight thru? or thru amp? amm3824 Audio, Video & TV 2 10-18-2010 08:32 PM
Flow Thru Exhaust and Muffler LKappenman Mechanics Corner - Engines, Transmission & More... 17 09-22-2009 11:29 AM
Good SAM rally in Hutchinson Kansas June21 thru 24th wb13798 Other Rallies & Events 2 08-27-2008 09:17 AM
