Old 01-15-2015, 11:48 AM   #15
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
That duct is there, but next to it is a removable piece of countertop that opens the little hole for venting..Doesn't look home made
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-15-2015, 01:05 PM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Pics would help.
Old 01-15-2015, 09:32 PM   #17
1968 26' Overlander
West Richland , Washington
My counter top also had a hole cut in it near the back with a piece of formica to cover it. I don't think it was for venting. It was an access to remove the flue baffle that is a part of the refrigerator (heater?). My replacement fridge also has a flue baffle but my new counter top will cover it so the only way to remove it will be to pull the fridge out of the opening.
JIMandPJ is offline   Reply With Quote
Old 01-30-2015, 10:42 PM   #18
(-1 Rivet_
REDSLED88's Avatar
1965 20' Globetrotter
Jackson , California
Louvered
I'm in the same boat. Right now I have a solid lower access door, and louvered upper access door for the fridge, and I think I'm just going to switch them, putting the louvered on the bottom....
Altough if I find one I may just go for both.
Is there a reason the upper access door would be louvered?
It sits just at the top of the fridge. I as well have the mesh hole in my floor, but will be replacing entire floor. So maybe the upper louvered access door creates some kind of venturi effect (lol), who knows.
TIMK
Thanks in advance!
TAC CA-77
REDSLED88 is offline   Reply With Quote
Old 02-01-2015, 10:30 PM   #19
1968 26' Overlander
Don't think I've ever seen an upper and lower access door for the refer. Mine is a lower door only and I'm still looking for someone local to put louvers in it.
'75 Overlander - Need new vent vent covers Ultradog 1975 Overlander 8 07-21-2014 07:16 AM
2010 Int'l: Does cable coax go straight thru? or thru amp? amm3824 Audio, Video & TV 2 10-18-2010 08:32 PM
Flow Thru Exhaust and Muffler LKappenman Mechanics Corner - Engines, Transmission & More... 17 09-22-2009 11:29 AM
Good SAM rally in Hutchinson Kansas June21 thru 24th wb13798 Other Rallies & Events 2 08-27-2008 09:17 AM
