Old 09-25-2017, 08:11 PM   #1
2018 16' Sport
New York , New York
Refrigerator too cold
2018 sport Bambi only purchased 10 days ago .. everything in our refrigerator is freezing and it's a factory adjustment temperature with no controls.. has anyone had this issue ?
Cedargirl is offline   Reply With Quote
Old 09-25-2017, 08:27 PM   #2
dasams's Avatar
Marin , California
Yikes! When I saw the title, I was going to post 'lower the temp setting from a 5 to a 4'. A refrigerator without an adjustable set point is not a good idea. Sorry and hope it works out. Dave
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 09-25-2017, 08:55 PM   #3
camperguy58's Avatar
Folsom , California
I'd suggest installing it in a Basecamp, that should take care of it being too cold.....
Pat
2012 Jumping Jack
Looking at Sport 22FB, maybe 16RB
2017 Honda Ridgeline Black Edition
Folsom, CA
camperguy58 is offline   Reply With Quote
Old 09-25-2017, 09:11 PM   #4
1979 23' Safari
Wayland , New York
Good one!!
Anyway, what model fridge is it? Should say on sticker on inside fridge wall by door.
HiJoeSilver is online now   Reply With Quote
Old 09-25-2017, 09:15 PM   #5
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Sounds like a thermistor issue which can be adjusted easily on most refrig units. It is attached to the fins inside the frig and acts like a thermostat depending on it's relative location to the freezer if you have one. You can slide it up and down to adjust the cooling.
If this doesn't work, you can also add it to your list of warranty items to be fixed and take it back to your dealer to be adjusted.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 09-26-2017, 03:32 AM   #6
Long Island , New York
Welcome to the forum!
What does your owner's manual say about adjusting the temp?
If you have a thermistor on the cooling fins at the top of the fridge's interior, as already suggested, you would slide the thermistor down for warmer. There are usually some hard-to-see labels which help you align the thermistor for best average temp.
Memory mnemonic:
Up north it is colder
Down
south it is warmer
Good luck!
Peter
PS -- I would call your sales rep for guidance also.
Heat Pump - How cold its too cold? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-09-2014 06:03 PM
refrigerator - not too cold JourneytoRet Refrigerators 11 08-25-2013 10:56 AM
Too cold to polish? 72Blazerod Cleaning, Stripping & Polishing 3 03-07-2006 07:18 AM
Frig too cold gklott Refrigerators 2 10-04-2003 02:14 AM
Refrigerator too cold wingfoot321 Refrigerators 1 09-08-2003 09:13 PM
