Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 08-13-2006, 09:21 AM   #1
gaylejoe
gaylejoe's Avatar
Profile:  2003 25' Safari
St. Hedwig , Texas
Refrigerator is sweating
We have noticed that our Dometic is going through a cycle of sweating. The freezer is maintaining it's temperature. The coils freeze over and moisture starts dripping in the frig. The temperature thermostat is set on 4. What is the problem????
gaylejoe is offline   Reply With Quote
Old 08-13-2006, 02:22 PM   #2
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
humidity!
ammonia fridges are not like frost free models you are used to in your home.
they only cool to a set level and will ice up if set too cold, most have a drip tray to remove the excess moisture to the outside. mine ices up at night during hot weather and will thaw during the heat of the day and drip. this is normal.
if it bothers you try a slightly higher setting and see if it helps. also, make sure your drip tray is in place and not plugged.
john
you call them ferrets, i call them weasels.
Old 08-13-2006, 04:29 PM   #3
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Humidity Indeed!
You may be opening the door a lot or for long periods of time. Also, there might be a small area where the door seal gasket is not sealing properly and admitting it the tiniest amount of outside air. Try the dollar bill test all around the door gasket to be sure that it is completely sealing against the frame.
Otherwise, the drip tray and drip hose that are found on these type units in the fridge section are there for this very reason.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 08-13-2006, 06:16 PM   #4
26.982 amu
Profile:  1972 29' Ambassador
Tyler , Texas
What next?
The dollar bill test fails on my old Dometic. Is there an easy fix, or do I have to replace all the seals?
26.982 amu is offline   Reply With Quote
Old 08-13-2006, 08:20 PM   #5
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Keep in mind that you may have a high humidity switch on your fridge which will warm the surfaces around the door gaskets and keep that area from sweating. If you have the switch, just don't forget to turn it off once you are done with your outing. Mistakenly leaving that switch on runs down a lot of parked trailer batteries.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 08-13-2006, 08:26 PM   #6
lewster
Commercial Vendor
lewster's Avatar
Vince,
Unless someone on the Forum has had a better experience, I have always replaced the door gaskets if they don't provide the proper sealing action. On new units still in warranty, the refer companies will usually just ship new doors . I guess thay don't have faith in their dealer network to properly replace the gaskets!!!
AIR # 10325
Old 08-13-2006, 08:48 PM   #7
gaylejoe
gaylejoe's Avatar
St. Hedwig , Texas
What I ment to say was the bottom portion of the frig is wet on the inside, not the outside. The temp is around 50 F. The coils are freezing up. Thermostat is at 4. The frig door is not being opened a lot. We are at home and always keep it on. To me, the frig seems like it is de-frosting.
Old 08-13-2006, 10:28 PM   #8
gaylejoe
gaylejoe's Avatar
St. Hedwig , Texas
I may have found the problem. The coils are frozen over, the freezer is cold, so the unit must be working. I believe the door seal is the problem. There is an area on the lower portion of the door which is not sealing correctly.
Old 08-14-2006, 06:56 PM   #9
26.982 amu
Tyler , Texas
Replacing gaskets
Lewster said: "I have always replaced the door gaskets if they don't provide the proper sealing action."
Where is the best place to get these? Mine is a pretty old unit.
Old 08-14-2006, 07:54 PM   #10
lewster
Commercial Vendor
lewster's Avatar
Vince,
Try giving Dometic a call (assuming that you have that make). They will point you toward a distributor that will have the right gasket set for your unit. www.dometicusa.com.
AIR # 10325
Old 08-16-2006, 09:07 PM   #11
gaylejoe
gaylejoe's Avatar
St. Hedwig , Texas
I purchased the gasket for RM77D from Camping
World yesterday for $77.
How to get crome walls like the new 2004 Bambi outerbanksdeb General Interior Topics 16 06-04-2004 09:30 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
