Old 07-15-2008, 04:52 PM   #1
1995 28' Excella
Seguin , Texas
Refrigerator repair or replace?
We recently purchased a 1991 B190 knowing the fridge does not work. A local shop suggested we replace the cooling unit and we told him to go ahead with the work. The first cooling unit he received from the supply house was defective and we are now waiting for a second cooling unit. In the mean time, I have read that we may be money ahead replacing the entire fridge. I can purchase a Dometic 2351 2-way fridge for less than what the technician will charge to replace the cooling unit. If I decide to replace the fridge myself, how much trouble will I get into and will I have to modify any vents? What "cautions" are recommended when replacing the fridge?
DGBMLB is offline   Reply With Quote
Old 07-15-2008, 04:56 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums. We went through the same thing with a fridge we got. It had a bad cooling unit, and the place we got it from replaced the cooling unit--3 times. I finally gave up, and got a brand new ridge, installed it, and have had no further problems. I would suggest a new fridge, unless you want to practice taking your fridge out for a walk every couple of months.
Old 07-15-2008, 05:15 PM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
New fridge, the Dometic is great! We had one re-built that failed in two months. Remember to defrost.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 07-15-2008, 05:39 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
One VERY IMPORTANT thing to remember: you get a 3 year warranty with a new Dometic fridge......and usually 90 days with a replaced cooling unit. The icing on the cake is that you can get a new unit for less than the repair.....
The answer should be obvious at this point!
Old 07-15-2008, 05:52 PM   #5
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Its still blurry
Originally Posted by lewster View Post
... The answer should be obvious at this point!
The problem I will face when my 41 year-old refrgierator makes it's last ice cubes is a replacement that will fill the space available without substantial modification.
A little bit smaller is one thing since we don't full-time. But major mods which upset the original look bother me.
My post is probably moot, though, since I am told no one rebuilds my original unit anymore.
Tom
Old 07-15-2008, 09:05 PM   #6
1995 28' Excella
Seguin , Texas
Thanks to everyone who replied! I will try to buy a new fridge. Will a new fridge require a professional to install it, or can I do it myself?
Old 07-15-2008, 09:16 PM   #7
Mike Leary's Avatar
Images: 11
With gas & power, I'd let the big dogs do the change-out & I mean the
really good big dogs, Dometic has black door panels that look neat in the AS.
Old 07-15-2008, 10:54 PM   #8
lewster's Avatar
The AC/DC connections are probably there already....usually no biggie! 2 wires for the DC and just a plug-in for the 120VAC. LP is another story. If you are not familiar with LP installations, leak detection and proper connections of flair fittings, then by all means......have a qualified shop do the job. Hopefully, they have at least one person with a state LP certification
Old 07-16-2008, 06:01 AM   #9
1995 28' Excella
Seguin , Texas
I appreciate all the quick responses and advice. Be "talking" to you later.
Old 09-02-2008, 07:53 AM   #10
Where did you buy the 2351 Dometic?
911rs is offline   Reply With Quote
Old 09-02-2008, 09:23 AM   #11
1969 29' Ambassador
orange Park , Florida
Lewster,
I have heard that if a fridge sits awhile it could quit working and be presumed bad. I was told the fridges are filled amonia instead of freon, and that the amonia will settle in the bottom. I was told that you can unplug and pull fridge out, flip fridge over on top and let sit 24 hours. Then flip back over and let sit 2-3 hours and reconnect. It should work after that, heard anything on that procedure?
69AmbassFl is offline   Reply With Quote
Old 09-02-2008, 10:06 AM   #12
richinny's Avatar
2011 34' Classic
go to the search tab and google search burping. there is plenty to read.
Ricky
Old 09-02-2008, 11:19 AM   #13
lewster's Avatar
Originally Posted by 69AmbassFl View Post
Lewster,
You are partially correct. RV fridges are filled with mixture if ammonia, hydrogen and sodium chromate (an anti-corrosive). It is highly unlikely that the components 'separate' in the static phase of sitting around, but there have been reports of successful 'burping' episodes)...........
If you would like to 'burp' your unit, you can remove it from it's position after disconnecting it from the AC/DC/LP and turn it on each side and top for 15 minutes, then stand it upright and rock it on each of the 4 corners tilted to 45* for 1 minute each....then re-install it. This will definitely clear any potential settling problems you may have!
Keep us posted on your results.
Old 08-31-2011, 06:12 AM   #14
1976 31' Sovereign
Pittsburgh , Pennsylvania
I know this is an old thread but I just tried this prior to giving up on our fridge.
It worked!
Thanks for the great advice!
You saved us a lot of $$$
Mikal
gronlampa is offline   Reply With Quote
Replace the refrigerator?? mrauch Refrigerators 7 05-24-2008 11:26 AM
what about replace dometic refrigerator with a home refrigertor? tracyhugs Refrigerators 15 02-27-2008 04:36 AM
Skin Repair or Replace? MarkExc500 1978- 1979 Excella 500 1 04-04-2006 01:12 AM
repair or replace a/c? hively Furnaces, Heaters, Fireplaces & Air Conditioning 12 07-19-2004 11:37 PM
Replace 110V Refrigerator Heat Element JimBrownUT Refrigerators 1 11-29-2003 01:41 PM
