Old 01-14-2004, 09:25 AM   #15
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
It is blowing out
In the past, with a street-side refrigerator in two of my previous SOB trailers, I had the same problem of the refrigerator blowing out and fixed it with a small baffle that I conjured up out of some scrap aluminum. In one case, gusty Texas winds were all that was needed to blow out the flame, in the other it was passing trucks that caused the blowout.
My current Classic has the street-side refrigerator, but it is installed so deep into the trailer that I haven't had any problems with blowout even though there is no baffle installed.
I was lucky that my first attempt at installing a baffle fixed both of my previous blowout problems. I can only recommend that you do some cut and try with some thin metal.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 01-14-2004, 09:30 AM   #16
Pahaska's Avatar
Hays County , Texas
Re: Might Still Be Electrical
Originally posted by 87MH
Josh:
Truely, the problem could be electrical or mechanical (air current related).
One more thought on the electrical side.
The current requirement for the Dometic 3800 is about 24 amps DC.
This is, relatively speaking, a large load.
Reread his post; he is running on propane, not on DC. His check lights are because the flame went out or blew out. The refrigerator in question is a 2-way refrigerator and the current load is negligable.
John W. Irwin
WBCCI #9632
Old 01-14-2004, 10:09 AM   #17
87MH's Avatar
1978 31' Sovereign
Images: 292
Type of Fridge unknown.
John:
Josh states his propane system does not work, but we still don't know if his unit is 120/propane or 120/12/120.
Following my diagnosis of the 12 volt low voltage scenario (relight delays caused by intermittant 12 volt heat cycles), this could still be the cause of Josh's no cooling while travelling problem.
I'm in 100% agreement that, if he has a 120/propane system only, your assesment of wind problems is accurate.
IF, however, he does have a 3 way unit, a simple check would be to disconnect the high amperage 12 volt feed (separate from the circuit board feed), which would permit the unit to run on 120 or propane only, taking the 12 volt cycling possibility entirely out of the picture.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 01-14-2004, 10:17 AM   #18
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I'm not sure Airstream installed any 12/120/LP units in 2004 or 2003. Don't quote me on this though.
Old 01-14-2004, 10:35 AM   #19
Pahaska's Avatar
Hays County , Texas
DC refrigerators
AFAIK, Airstream currently does not offer a 3-way refrigerator in any trailer line and has not for some time. I was in the 28' CCD at the dealer last week and it had precisely the same 2-way refrigerator as I have in my 2003 Classic.
John W. Irwin
WBCCI #9632
Old 01-14-2004, 03:57 PM   #20
joshua32064's Avatar
Just for clarification, the refrigerator is 120/propane. It is absolutely and without a doubt a two way fridge and not a 3 way.
joshua32064 is offline   Reply With Quote
Old 08-18-2004, 02:20 PM   #21
I have a 2004 Bambi and my frig. is LP,110,12-volts. Even when on 110 you need 12volts to power the circuit board that directs the frig. functions.
cynthia is offline   Reply With Quote
Old 08-18-2004, 06:10 PM   #22
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 53
Same issue in our 2004 Classic. Shield preventing blow-out solved the problem.
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2003 GMC Sierra 2500HD CrewCab/Shortbed diesel
Hensley/Prodigy
gklott is offline   Reply With Quote
Old 08-18-2004, 07:59 PM   #23
Cracker's Avatar
Pittsfield , Maine
Wow! This thread has been floating around for a long time since Joshua first mentioned he was having problems. I solved the problem by fitting an air-conditioner filter in the frame opening behind the refrigerator exterior vent. The A/C filter was one of those simple foam filters with the plastic ribs molded in on about 4" squares. You can buy the filter larger than the opening and then cut it to fit. Since it's flexible, it makes for a neat installation. I take ithe filter out when I'm parked - but logic says that the "free-air" flow of the filter is probably greater than the "free-air" flow of the louvered access door. In other words, I think that it could stay in place - but why chance over-heating the frig?
Cracker
Cracker is offline   Reply With Quote
Old 10-11-2004, 01:37 PM   #24
kiwicafe
Pakeha's Avatar
2005 22' International CCD
Featherston , Wellington
Send a message via Skype™ to Pakeha
re: refrigerator issues
I own a 2004 22' CCD International trailer.
All my powerpoints inside and outside the trailer, with the exception of the powerpoint under the computer desk, do not work. I cannot find anywhere in the user manual where to start troubleshooting. I have checked all the fuses, all seem okay. I would love some urgent help with this as I am about to take off on a 3000 mile trip, regards, Richard.
Pakeha is offline   Reply With Quote
Old 10-11-2004, 02:05 PM   #25
Pahaska's Avatar
Hays County , Texas
Since you include "outside the trailer", I have to assume that you are talking about 120v outlets. These aren't fused, they are controlled by circuit breakers in the AC breaker box which should be somewhere close to where your AC cable enters the outside of the trailer. Sounds like you have one or more popped circuit breakers.
John W. Irwin
WBCCI #9632
Old 10-12-2004, 10:14 AM   #26
kiwicafe
Pakeha's Avatar
thanks pahaska from pakeha, can't quite change a couple of letters but close.
I found the problem last night and as you so rightly stated the curcuit breaker was "popped", so all is well that ends well.
Do you have anyrecommends for service manuals for Airstream as I find theirs a tad, read somewhat, read very, confusing at times. For a person new to this trailering lifestyle I would like a 'simple english' book to read.
Any thoughts? And thank you for your reply, Richard.
Old 10-12-2004, 01:26 PM   #27
jimmickle's Avatar
2000 31' Land Yacht
Have you thought about just shutting the refrigerator off before traveling? In our 2002 Safari, this works just fine. Everything stays cold, and the Ice Cream doesn't melt. Just keep the unit relatively full and the doors closed. If you think you need more cooling, turn it on when you are stopped for lunch or at a rest area.
jimmickle is offline   Reply With Quote
Old 10-16-2004, 06:09 PM   #28
12 volts needed
Most recent dometic fridgs. need 12 volts to run the circuit board. If there is a problem be certain the check the ground on the circuit as well as the 12 volts. On the older three way, a sense line from the tow vehicle, a switch at the fridg will allow the fridg to operate when driving.
Lyall is offline   Reply With Quote
