Old 08-18-2012, 06:11 AM   #1
2011 30' Flying Cloud
Arvada , Colorado
Refrigerator On - no hookup
I expect to be in a situation where I'll need to park our AS for 3-4 days with no hookups. I know that there are a lot of variables, but what can I expect in terms of battery capacity in leaving the refrigerator on? Thanks. Jack
Jack46 is offline   Reply With Quote
Old 08-18-2012, 06:19 AM   #2
JDS
2014 Bowlus Road Chief
JDS's Avatar
Cumming , Iowa
Doesn't it switch to propane when not plugged in to shore power?
JDS is offline   Reply With Quote
Old 08-18-2012, 07:28 AM   #3
Arvada , Colorado
Yes, but as far as I know some battery power is required for operation of the refrigerator?? Maybe I am incorrect which would be good news, but it seems to me the battery cutoff switch must be on for the refrigerator to be operational.
Old 08-18-2012, 07:34 AM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
The only power that it needs is to run the control board and the spark to light the burner. Very little is needed. You could have it on for a week and probably would hardly notice a drop in your batteries. I had mine on for 4 days, using lights at night and the fan once in a while during the day. My batteries fell to 80%.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-18-2012, 07:48 AM   #5
Central , Mississippi
On my fridge, there is a hi/low humidity switch visible when the freezer door is open. If that switch is "on", the fridge pulls 1.5 amps. If you have a single battery that will pull you down below 50% in just a couple of days! By turning it "off" the draw slips to .7 A allowing for 3-4 days before the battery drops to 50%...in theory
All of this is based on my fridge and a single 80AH battery...your milage may vary...
In actual use, I have 3 80AH batteries and the fridge pulls me down 3% of usable capacity per day. I'm guessing the frige cycles off at some time during the night.
Of course it only takes a small portable solar panel to make up for the .7A loss...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-18-2012, 10:08 AM   #6
Arvada , Colorado
Thanks for the input. This trip will be to Oklahoma in July so I suspect the refrigerator will work overtime a bit. But, I think we should be fine. Jack
Old 08-18-2012, 01:05 PM   #7
colberjs's Avatar
1964 30' Sovereign
Porum , Oklahoma
Where at in OK?
colberjs is offline   Reply With Quote
Old 08-18-2012, 02:02 PM   #8
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Hello,
Looks like good advice and information above! I would also ask if it has fans that operate to circulate air in the 'fridge... those can pull some power. Some sort of back up system like a generator to recharge the batteries might be a suggestion if you are really worried, or perhaps a solar charger that keeps the batteries up?
Have fun!
Mrs. NorCal Bambi traveling in S Tardis ~ from the Great State of Jefferson!
My blogs: http://yrekahistory.blogspot.com
http://siskiyoucountycamping.blogspot.com
http://campingalongi-5.blogspot.com/
CaddyGrn is offline   Reply With Quote
Old 08-18-2012, 02:13 PM   #9
Arvada , Colorado
This is obviously next summer. I'm going to attend a business meeting in late July in OKC in advance of ending up on the WBCCI Southwest Caravan. Since it would be lot more comfortable to stay in the meeting's hotel, I will be looking for a three-four day dry storage. We'll be then heading to Mount Rushmore, Little Big Horn, Glacier, Yellowstone and then on to our daughter's home in Aspen before the start of the Caravan in Durango in late August. Though I've ridden to all these spots solo on my BMW motorcycle, this trip will be a three month long retirement celebration by the two of us.
I overlooked that I do use a small solar charger when the AS is stored. That will help with the fridge as well.
