Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 09-22-2019, 10:56 AM   #1
Courtenay , British Columbia
Refrigerator not cooling
My 25FB was parked overnight on steep incline with fridge running on gas. Next day fridge is no longer cooling. I suspect the refrigerant pooled in the coil.
Will this problem correct itself now that the trailer is level?
Anyone had this problem? If can you help?
Courtenay is offline   Reply With Quote
Old 09-22-2019, 12:52 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I'm not aware of a refrigerator recovering from off-level operation of that duration. The literature states 45 minutes as the maximum period for off-level (>15 degrees?) operation.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 09-22-2019, 02:30 PM   #3
1986 31' Sovereign
Miami , Florida
Tow it some with it off and see if you can redistribute the coolant then try it on 110vac.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 09-23-2019, 09:17 AM   #4
Thanks for your help. I can happily report that I switched off the fridge for 8 hours while levelled up and the fridge is now running like new.
Old 09-23-2019, 01:12 PM   #5
1986 31' Sovereign
Miami , Florida
Cool beans!
Young, lovely bride
Dismissive cat
Dometic Refrigerator NOT COOLING sufficiently ctimberlake Refrigerators 3 09-15-2018 01:58 PM
Help! Domestic refrigerator not cooling. NWRVR Refrigerators 15 09-18-2016 11:07 PM
Refrigerator not cooling jimpappy Refrigerators 2 06-21-2012 08:54 PM
Refrigerator gurgling, not cooling Pacerized Refrigerators 7 04-21-2010 07:54 PM
refrigerator setting for maximum cooling qqq Airstream Motorhome Forums 5 07-19-2003 04:21 AM
