Old 01-26-2007, 08:47 PM   #1
2004 28' International CCD
Los Angeles , California
Refrigerator/lights out
This evening when I changed the light bulbs in my 2002 Classic bedroom and attempted to turn the light back on one of the ceiling lights flickered and then went out. The refrigerator also went out--the panel lights won't come on even to run the fridge on gas--and now none of the lights in the bedroom will work, even though a wall outlet in the bedroom works and the microwave works too. I unplugged the whole trailer at the hook-up and checked the circuit breaker out at the street (shut it off and turned it back on). The circuit breaker inside the trailer doesn't seem to be fixing any of these problems either. Yikes! Does anyone have any suggestions?
Monty is offline   Reply With Quote
Old 01-26-2007, 09:21 PM   #2
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
check your batteries. bat was low on charge. charged up batt then everything worked..
just want to camp happy
bobchevy89 is offline   Reply With Quote
Old 01-27-2007, 05:31 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
converter
Monty,
If you're plugged in and you're not getting any 12VDC for the fridge, lights, etc....check the fuses in the converter and the output of same. You may have run down your batteries due to them not getting any charge from the converter.
