Can't say from information given. Did it ever work? Get a new bulb and try it. If not that, could be the switch in the door. I'm not aware of a switch to turn it off, but the "low ambient" switch, if you have one, will turn it on all the time. If you have it, turn it on. If the bulb doesn't light, either bad bulb or wiring has been changed to keep it off.
Al
You cannot reason someone out of a position they have not been reasoned into"
