Old 10-04-2011, 07:28 PM   #1
1989 25' Excella
Murphys , California
Refrigerator issues
I've got an 89' Airstream Excella 25 with refrigerator issues. The refrigerator works fine on 120volt and the freezer works fine on LP gas, however, the main storage area does not cool at all on LP gas. Had the unit into a service center and they were stumped. Pressure has been checked, venting, flame all good. Cooling unit seems to work fine, does anybody out there have a clue as to what the problem might be? Thanks so much for any ideas. Model is Dometic 2601.
Ernst is offline   Reply With Quote
Old 10-04-2011, 08:31 PM   #2
Refurbished 89 Excella
DKDarrow's Avatar
Sugar Valley , Georgia
Two things.......did you clean the apeture on the burner? Yes, the flame may look good but did you clean that apeture.....IT IS EASY TO DO>>>>Yes, the freezer will get cold and freeze but not COLD with the main compartment NOT getting cold at all.
The line coming off the coil up at the top going down to the main compartment could possibly be "plugged". Try tapping....not beating or abusing....tapping on it along its length.....
Maybe some ventilation also in the form of an additional fan??????
I know from experience this summer in the heat for 6 weeks in Tex, Ok, NM, Utah, and Colo that these little things sure got rid of the exact same problems.....Ended up having to clean the apeture like 3 times.....I must have crud in my gas lines or something.......Anyway...works for me.....God bless.......Dennis
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
DKDarrow is offline   Reply With Quote
Old 10-04-2011, 08:39 PM   #3
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Try The Service Manual
This link will take you to the Dometic Service Manual which has a trouble shooting flow chart to assist you in determining the issue.
http://webspace.webring.com/people/j...ice_Manual.pdf
SeeMore is offline   Reply With Quote
Old 10-04-2011, 08:44 PM   #4
The burner and oriface "MUST" be cleaned every 2 to 3 years, for best cooling.
Also, check the LPG presuure to make sure it's at 12" of water column pressure, but no more than 13".
If that service center was stumped, I think you need to find a different one.
Old 10-05-2011, 08:51 PM   #5
1989 25' Excella
Thank you!
Thank you, I'll try your suggestions this weekend and hopefully it will work.
Old 10-05-2011, 09:02 PM   #6
1989 25' Excella
I gave the link a try but it would not load. Would you mind telling me where I can find the pdf file your talking about?
