Old 10-20-2015, 08:46 PM   #1
1984 31' Sovereign
Westerville , Ohio
Refrigerator issue
Picked up my late Grandfathers AS this weekend and brought to Ohio from Florida. I have many many questions but will start with this one. The Dometic model 2820 installed in 2002 and used very little is blowing the 5A fuse inside the black plastic box behind the refrigerator. I turn off the power in the back replace the fuse and then turn the power back on. My daughter goes inside and turns on the refrigerator as soon as it calls for power it blows the fuse and then clicks over to LP and try's to fire. I do not have the gas on so I'm not sure if it will run or not. Can anyone guide me into the next place to look?
Rick
RickJacobs13 is offline   Reply With Quote
Old 10-20-2015, 09:41 PM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I looked for a manual for your fridge... found it here: http://www.dometic.com/QBankFiles3/E...nual_17596.pdf
Page 11 says the 5A fuse is for the AC heater. Page 15 lists the part number for the heater..... 17 37 42-18/0. I would figure out where that heater is, look for any obvious shorts, eliminate them if possible. Otherwise, order a new heater and install it... maybe here?? Dometic 110 Volt AC Heating Element 3850644422 (325W 120V) -
Whats good for me may not be good for the weak minded.
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 10-20-2015, 10:27 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Your 120VAC heating element probably has an internal short in the cal rod. It needs to be replaced. A simple continuity test will confirm this.
Just be prepared for a real tussle trying to remove it from it's steel tube housing.
Old 10-21-2015, 08:36 PM   #4
1984 31' Sovereign
Westerville , Ohio
Thank you for the help, you are both right. I put in a new fuse pulled the J7 and J8 plug from the board and turned on the ref. The ac light came on and the fuse didn't blow. I turned the ref off right away and then began removing the heating element. Again you are right it was hard to remove. First problem is whoever installed the last heater didn't put it in the tube. It was shoved down inside the insulation next to the tube. It was fused and broke off when I removed it. I ordered a replacement element on Amazon for $45 and free freight. It will arrive on Friday.
Thank you again for the help.
Rick
Old 10-21-2015, 09:04 PM   #5
PaulnGina's Avatar
Good Ol' , USA
Don't you just LOVE Amazon? I get a lot of stuff from them. If they have it, they'll have the best deal. Too bad they don't sell Airstreams!
1987 Avion 34W
Old 10-21-2015, 09:12 PM   #6
1984 31' Sovereign
Westerville , Ohio
Use Amazon everyday to order parts and other items we use at my Job. Save thousands of dollars a year for my company.
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Refrigerator issue.. won't run when switched to LP ? Focusfactor1 General Repair Forum 6 07-25-2013 09:18 AM
1976 Argosy 24' - Dometic Refrigerator issue NAM_FL Refrigerators 1 05-21-2013 10:51 AM
Compact Home Refrigerator or RV Refrigerator? mattsteel Refrigerators 26 04-05-2011 01:30 PM
Window replacement issue davespann 1966 - 1968 Safari 4 09-09-2008 04:20 PM
