Old 05-28-2012, 07:35 PM   #1
1965 26' Overlander
new ringgold , Pennsylvania
refrigerator igniter
Help,I have a 65 landyacht with its original frige,however i am disabled and have a problem with getting on the floor ,laying on my side and pushing in on the pilot button while trying to spin the ignitor wheel to get a spark all too much for me. I read somewhere, some time, in the past where someone, adapted a device that with a small battery and some sort of electrode created a spark that would light the gas flame . I am handy and certainly could install such a device if someone smarter than myself could point me in the right direction.Any advice would be greatly appreciated.Thanks Carl
carice2 is offline   Reply With Quote
Old 05-28-2012, 11:12 PM   #2
195Pilot's Avatar
1975 31' Sovereign
Pierre , South Dakota
You should be able to access the rear of the refer(this is where all the control knobs connect to there valves etc.) outside the trailer through a door. You can simply hold the valve down and light the pilot light with a lighter. My ignitor pushrod is broken and thats how I light the refer.
hope this helps
Jack
195Pilot is offline   Reply With Quote
Old 06-04-2012, 12:53 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
hope this helps
Jack
I am having a similar problem, the push rod igniter seems to be dead (no spark). I was wondering if it was safe to manually light the pilot from the rear. I guess I will give that a try this evening.
MICHAEL
Old 06-04-2012, 01:22 PM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Check this thread for more insight:
http://www.airforums.com/forums/f425...itor-7652.html
Tom
