Old 11-20-2007, 07:05 PM   #1
1976 31' Sovereign
Charlotte , North Carolina
Post Refrigerator Heating Element
I have a 1973 Airstream International and the local camper repair shop told me that my heating element was defective and that replacements where no longer available. The gas portion works fine but I am preparing to sell my AS and would like to get my fridge up and running electrically. Can anyone steer me in the right direction so that I can locate the heating element so that everything works for the buyer?
Any help will be appreciated.
Badco8 is offline   Reply With Quote
Old 11-20-2007, 07:36 PM   #2
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Try "gas refigeration.net'' also Ebay sometimes has some. I think it would be smart to pull the old one,it should have the wattage stamped on it.Did the mechanic do an olhm reading?It could be the electric thermostat.the older units had separate T-stats,for gas and electric.
Doug
bibbs is offline   Reply With Quote
Old 11-20-2007, 08:41 PM   #3
Coastalview's Avatar
2002 27' Safari
Carmel-by-the-Sea , California
Images: 14
Send a message via AIM to Coastalview Send a message via Yahoo to Coastalview
Try these guys for new and used parts, same folks that Doug posted:
120v heaters
There here on the west coast, but will ship certain parts.
Jeff
AIR: 649
TAC: CA-40
Northern California Airstreamers
Coastalview is offline   Reply With Quote
Old 11-20-2007, 09:04 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Badco,
Do yourself a favor an perform this little test. Follow the wires from the element back to the control board. Remove the 2 wires for the element that plug into the board, and using 14 guage jumper wires, plug the element directly into a 120VAC outlet. If it's good, it will begin to get noticeably warm in about 10 minutes.
If not, unplug it and do a continuity test on the element with a multimeter set on resistance. If you get no reading, there is no continuity in the element and it is bad.
If so, measure the legs of the element and the diameter and let me know what they are. If you can't find one, I'll do a search of my suppliers for you.
Old 11-20-2007, 11:57 PM   #5
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Try almost any "mom and pop" RV parts place that has been around for awhile. They often have several dust covered packages of various wattages. I've had good luck in several places in the West.
Zep
Heating element in Dometic fridge Ultradog Refrigerators 7 03-11-2015 12:49 PM
New heating element didn't fix the problem. 29348 Refrigerators 3 11-30-2007 05:11 PM
Oven heating element, Caravel ncsuzy Stoves, Ovens & Microwaves 6 04-28-2005 05:03 AM
Suburban Heating Element Fallman Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-29-2004 07:13 AM
Source for Heating Element foe Norcold 624 srgntpepper Refrigerators 2 05-11-2004 05:02 PM
