Old 06-25-2019, 11:38 AM   #1
2018 30' Classic
Traverse City , Michigan
Refrigerator flipping from LP to Elec constantly
We have a 2019 30í Classic. Had it in to the dealer for the typical list of things that needed fixed including our refrig that keeps frosting up. When we picked it up and reviewed the repairs I mentioned to the service manager that the source display was flipping back and forth between LP and Elec. He said heíd have his guys check it. Out for a short trip, set up, and itís still doing it. In 2 years itís never done this before. Any ideas what might be happening?
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30í Classic
SMKovalchik is offline   Reply With Quote
Old 06-25-2019, 12:14 PM   #2
dznf0g's Avatar
Oswego , Illinois
Are you set on auto? On shore power and switching to gas? Or on gas and switching to electric?
My first suspicion, if on auto and on shore power, is the board...or intermittent 120v power to the back of the fridge. Try unplugging and plug back in. Test the 120v socket.
-Rich-
Old 06-25-2019, 01:33 PM   #3
1977 27' Overlander
FINDLAY , OH
Try Purging the gas line
I had a similar problem. The manual says to turn off the fridge then turn it on again. It should try to purge the line if it is not plugged in.
Mine worked after a couple attempts.
ShadyBill47 is offline   Reply With Quote
Old 06-25-2019, 07:57 PM   #4
2018 30' Classic
Turning refrig off then back on cleared the issue. Thank you so much.
2018 30í Classic
Old 07-07-2019, 11:59 AM   #5
2016 19' Flying Cloud
Newtown , Connecticut
Our fridge worked great for three weeks on propane, but after re-filling the tanks, the "check" light would come on when propane was selected and the fridge would not stay cold. The fridge continued to work fine when on electric and plugged into shore power. Any suggestions on how to rectify the propone mode?
brundom is offline   Reply With Quote
Old 07-07-2019, 12:06 PM   #6
2007 22' International CCD
Probably have a propane flow problem. First, try lighting the stove. May be air in the lines or a tank excess flow valve problem.
If the stove does not light at all, or gas is not flowing, turn off the tanks totally. Wait a couple minutes, then slowly turn the tanks back on, one at a time. That may reset the excess flow valve in the tank valve.
Then try the stove again. If it now lights, try the fridge in propane mode again, a couple times. Turn it on and off to get any air out of the gas line to the fridge.
Also look into the fridge compartment and make sure the spark ignition is working and trying to light the propane. Check for a flame as well.
rmkrum is online now   Reply With Quote
Old 07-07-2019, 12:14 PM   #7
2017 28' International
Baileys Harbor , Wisconsin
When we switch to LP I always make sure I hear it come on or if the refrigerator is cold I stop after awhile and check to make sure it comes on. Then I listen to see if the flame is burning. Numerous times it doesn’t switch over on its own.
As stated above sometimes you have to turn it off, and then turn it back on to get the gas to flow better.
Once I opened both tank valves, and for some reason it worked. Maybe coincidence.
It will work. After awhile you get the hang of it.
PS. I would also invest in a small circulating fan in your fridge. It will keep a more even temperature and cool better.
Daquenzer is offline   Reply With Quote
Old 07-07-2019, 12:18 PM   #8
My guess is you need to purge the lines. Also are you getting a spark? Do you hear a clicking sound in the back when you switch to LP. The electric and LP heat the same thing, so itís not your fridge. If you get a spark and it doesnít ignite, itís a gas flow issue.
electric griddle - flipping breaker funkill Stella's Kitchen 5 07-03-2010 05:11 AM
Flipping Zip Dee Up Ganglin Awnings 7 08-08-2009 08:33 PM
Flipping axle for lift nmhuntr Axles 7 07-01-2009 12:50 AM
2007 Dometic AC is flipping the breaker oceanair Furnaces, Heaters, Fireplaces & Air Conditioning 8 06-20-2009 05:03 AM
Air conditioner breaker flipping cowpokemon1 Furnaces, Heaters, Fireplaces & Air Conditioning 8 05-27-2008 01:45 PM
