Old 10-30-2010, 10:29 PM   #15
Lew,
Thanks for the information on a 2011 27FB Classic. If the refrigerator needed to be removed, is that a big deal for a pro like you?
Barry
pattonsr is offline   Reply With Quote
Old 10-31-2010, 07:51 AM   #16
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by pattonsr View Post
Lew,
Barry
Removing a fridge is normally not a big deal.....except in an Airstream!
I don't know why, but they feel that they have to build the cabinets around the refer units and make it 2-3 times as difficult to remove them. ....... but they WILL come out!
Old 10-31-2010, 12:14 PM   #17
Gainesville , Florida
My AS does not have a fridge fan. I asked the dealer to be sure. zz
Old 10-31-2010, 03:08 PM   #18
wbrownrr's Avatar
2002 22' International CCD
San Luis Obispo , California
We replaced our noisy fan with a Silenex fan 4 or 5 years ago.... no more noise... adequate cooling in almost all conditions.
Wayne
2002 22' CCD
2008 Dodge Ram 1500 5.7L Hemi
wbrownrr is offline   Reply With Quote
Old 11-15-2010, 08:58 PM   #19
aftermath's Avatar
Spokane , Washington
No Fan Here
OK, I went in today and asked the guys at Airstream about the fan in the fridge. I was told that the coaches with the full size refrigerators that vent through the roof don't have fans unless they were installed as an after market thing.
The smaller fridges that vent out the side of the trailer have fans and some have a switch while others do not. He couldn't figure out why this was the case but he said that that is just how it is.
So, if you have a 25 footer or longer and are confused as I was, don't be. We don't have a fan unless it was added at some later time.
aftermath is offline   Reply With Quote
Old 11-15-2010, 09:06 PM   #20
dznf0g's Avatar
Oswego , Illinois
That is true throughout the industry. Theory is that if there is a straight shot out the roof, natural rise of heat will take care of cooling. If you must exit out the side , that natural rise is interrupted by the restriction of having to change direction. IMHO all refers need a boost of flow to provide adequate cooling of the coils.
Install a cooling fan and be done with it. I started adding fans with my first pop-up in 1984 and never looked back and never have had an unsatisfactory performing refer. My .02$
Old 03-01-2011, 07:03 PM   #21
Baton Rouge , Louisiana
I'm a new owner, so forgive any stupidity: I, too, have a refrigerator fan on 2008 Safari that doesn't stop running when fridge is off. Is the fan designed to do this? It has been unusually warm, and it's good to know there is thermo switch, but I don't want to have to remember to plug in the fan every time I fire up the fridge; and, since I frequently will camp without electric hook-up, I'm concerned about battery drain. Except for inefficient cooling, will it hurt the fridge to run with fan unplugged? Hal
halhml is offline   Reply With Quote
Old 03-01-2011, 07:39 PM   #22
2008 23' Safari FB SE
Boulder , Colorado
We also have a 2008 23fb and the fan noise was driving us batty. After lots of research on the forum, I ended up deciding between the snider product or ordering 2 silenx fans with low DBs as well as creating an aluminum barrier that forces more air to flow over the condenser with the 2 fans.
Since I like to tinker and build things, I went with creating a new mount for 2 silenx fans and creating an aluminum air break. It works great and we now sleep well!
If I were less inclined toward building things I would have gone with the Snyder kit.
Search for silenx and you will find pics of what I and others have done. This issue can be fixed with a bit of effort...
Good luck!
Sandy
bonginator is offline   Reply With Quote
Old 03-01-2011, 07:50 PM   #23
Thanks Sandy. But fan noise isn't a problem, surprisingly. The fan is very quiet--kind of a white noise. Then again, I haven't slept in the AS yet! I'm really concerned about battery drain, and the effect of unplugging the fan. I guess I'll just have to try the fridge with the fan unplugged for a few of these warm days to see if the fridge stays cool enough. It seems to be working--I wonder if it uses more propane with fan unplugged. Hal
Old 08-08-2012, 03:23 PM   #24
Mexray's Avatar
1978 28' Ambassador
Morada , California
You might want to check this refer fan with duct - they work great - I've seen it on a friend's frig!
Snyders RV Refrigeration - Home
with the addition of a baffle as noted above to direct the 'cooler' air toward the fan intake would seem to make it even better!
I have to admit, I bought one of Snyder's kits, but haven't gone to the trouble of installing it yet (you have to pull out the frig to get access) as our frig still does a great job...
I'm going to look closely at installing a baffle, however!
Ray & Pat; Morada, CA
Old 08-08-2012, 05:13 PM   #25
Zia
2011 23' FB International
2007 20' Safari
Irvine , California
We have the same problem with fan running all the time, I guess the coil temperature never get below 80 deg. F. On my requst the dealer installed a switch for the fan, unless it is very hot we keep the fan off when boondoging to conserve the battery. Some times we turned if off in the night to eliminate the noise, even though it is not very noisy fan
Zia is offline   Reply With Quote
Old 08-11-2012, 12:01 PM   #26
OldGreyMare
2009 23' FB Flying Cloud
1962 22' Safari
Honolulu , Hawaii
I have a 2010 23' FB Silver Cloud, and my refrigerator is loud, it sometimes sounds like someone is starting up a generator. I think I understand that that is the noise from the fan, can that really be possible? I am living full time in the unit this summer, and it is a hot one. Can someone help me with what size fan I need to get if I want to replace this noisy unit.
eastendmary,
Long Island, NY
eastendmary is offline   Reply With Quote
Old 08-11-2012, 12:48 PM   #27
2005 19' Safari
GLENDALE , AZ
The fan originally installed by the factory is a noisy computer fan. We replaced it with the silent model below, which is very easy to mount and wire; and it's an easy DIY project:
Amazon.com: Magma 12CM Fan Magma Component Twister Bearing Detach Blade: Electronics
Note: Above link is for reference purposes only. We actually purchased from a local Fry's Electronics store.
Gale-force winds through the back of the refrigerator are not needed to aid cooling; just enough breeze to move air through so heat doesn't build up, is sufficient. One fan is enough for our refrigerator, although two might help with larger models that produce more heat. We leave the outside refrigerator fan on 24/7 when camping, and while it would eventually drain the battery (we use one battery at a time via a marine battery isolator switch), it has no significant effect when compared to the FantasticFans, lights and other electronic items in use during an average day.
When open, the entry door blocks the exhaust vent; so I open the vent cover and put a six-inch section of swimming noodle over the edge, so it doesn't bang around and scratch the aluminum skin and/or open door. This improves circulation, when the door is locked in the open position. This may be unnecessary in milder climates; but in our summer heat, every little bit helps.
Refrigerator DC Fan campcollector 1997 - 2004 Bambi 24 11-29-2011 02:12 PM
solar refrigerator vent fan WineStream Generators & Solar Power 6 07-06-2010 07:57 AM
need help with refrigerator fan sport 16 Refrigerators 5 04-15-2010 04:31 PM
Refrigerator Fan CCD4US Refrigerators 10 03-23-2009 04:01 PM
noisy refrigerator fan Turtle 1997 - 2004 Bambi 9 06-03-2004 03:45 PM
