Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 10-15-2007, 05:22 PM   #1
CCD4US's Avatar
2007 16' International CCD
Rancho Palos Verdes , California
Refrigerator Fan
I have a 2007 16' CCD and I took the upper access door off and noted that the fan was blowing air out of the vent. Is this the direction the air is suppose to flow?
CCD4US is offline   Reply With Quote
Old 10-15-2007, 05:34 PM   #2
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Yep.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 10-15-2007, 05:34 PM   #3
Naples , Florida
Dear CCD,
I have replaced that fan on 3-16's in the past year. The owners complained that the fan was keeping them up at night from the noise, and the fridge was not getting sufficiently cold.
I would suggest that you remove the fan and replace it with a fridge booster kit from Snyder's Refrigeration (RV_Cool on these Forums). I am not associated with Mr. Snyder except that I have installed maybe a dozen of nis kits. They are properly designed and really WORK! (quietly too )
lewster
Old 10-15-2007, 06:29 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Yes, the fan is blowing in the right direction (outward) to take heat away from the frig mechanics...and yes, the factory-installed fan is not the quietest, as Lew points out... What's more, our fan was mis-wired at the facatory and was running continuously rather than going off & on with the temperature fluctuations as they are supposed to... Fixed under warranty.
TB
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 10-15-2007, 06:43 PM   #5
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Would these Snyder fans make a difference on a 2007 27FB with a refridge roof vent?
SilverCottage is offline   Reply With Quote
Old 10-15-2007, 07:41 PM   #6
myboyburt's Avatar
1993 25' Excella
Full Time , Anywhere USA
Images: 12
Yes it will. It has made a dramatic difference in the cooling capability of our fridge (93 Excella, newer fridge though). Worth the small amount of money and (some) effort to install.
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 10-16-2007, 08:39 AM   #7
Naples , Florida
You've got it right!
The Snyder kit directs the airflow in an upward direction across the condenser coils, drawing cooler air from the bottom vent. Plus, it includes a new, repositioned thermostat that properly reads the coolant temp as it is entering the condenser, providing the fan with accurate information.
Just for a test, I had my fan turned off in my 19CCD for a day. It was 90*+ here in FL yesterday, and the fridge temps went into the 50's. When I turned the fan back on, they are now headed into the low 40's and will probably end up in the high 30's, where they have been. And to add to this, the side of the trailer with the fridge is facing south into the sun most of the day.
The kit will work on any fridge!
lewster
Old 03-23-2009, 01:15 PM   #8
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
This is an older thread, are these Snyder kits still avaialble for fan replacement? Brad says on the 23' the fan is keeping him up late at night and sounding a bit like its about to go anyway. He wants to replace it with something quieter and perhaps put in an on/off switch. Though if its quiet enough I wouldn't think he would have to turn it off. He also says it vibrates the wall adding still further to the noise issue.
wheel interested is offline   Reply With Quote
Old 03-23-2009, 01:22 PM   #9
Lapeer , Michigan
I found another thread there are several with the fan kit web site and it looks like it is current. I will direct Brad over to there unless others have different ideas on how to they solved the problem in their AS. http://www.snydersrvrefrigeration.com/
I also found that thread mentioned previously onanother definitive fix by one of the members and it is here.
http://www.airforums.com/forums/f425...lly-11811.html
Didn't Rich Luhr also replace his fan or make a fan modification in his Airstream blog?
Old 03-23-2009, 01:24 PM   #10
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
They are still available and work well. I can barely hear mine. See http://www.airforums.com/forums/f425...aes-44474.html.
Vaughan
Old 03-23-2009, 04:01 PM   #11
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I've wondered if our Safari 25' FB has a fan in the refrigerator vent. I've looked for one, can't see one, but that doesn't mean there isn't one there. Anyone know?
By the way, the temp in the fridge is consistently 38˚ on the #3 setting regardless of the the outside temp or sun. We had a fan for the inside that ran on batteries; when we got it home, we found it had no switch. We'd forget about it and then when we would take another trip, the batteries were dead. After replacing the batteries a couple of times, it wouldn't stay together. We wired it together with some twist ties, but after the last time the batteries died, I just chucked it. Another quality product from CW.
Gene
Noisy Refrigerator Vent Fan rseagle 2002 - 2005 International 43 01-01-2016 07:49 AM
Refrigerator DC Fan campcollector 1997 - 2004 Bambi 24 11-29-2011 02:12 PM
Refrigerator Fan won't stop running tsunami Refrigerators 18 09-17-2007 01:50 PM
noisy refrigerator fan Turtle 1997 - 2004 Bambi 9 06-03-2004 03:45 PM
Refrigerator fan 2003 AS International Asgard 2002 - 2005 International 4 07-12-2003 07:05 PM
