Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 08-23-2014, 09:41 PM   #1
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
Refrigerator Error Code E0
Out refrigerator, Dometic RM 3762, stopped working today on the road. The error code 'E0' displays, then goes blank.
The owners manual says that that there is no communication between the display and power module. The 5 amp glass looked good, but its dark and I'll pull it in the morning. I have not checked the mini fuse but will do so in the am as well. J2 the plug to the display was seated ok.
Any other ideas?
Drew
drew05 is offline   Reply With Quote
Old 08-23-2014, 10:14 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Verify adequate power, not just fuse is good. Test power after the fuse tun on board if possible. Check voltage while powering up may require a patient assistant. Good luck!
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-24-2014, 09:11 PM   #3
drew05's Avatar
Peculiar , Missouri
cwf,
Thanks for your tip. I re-read the owners manual and re-tried the service mode (it didn't work last night). After going through all of the steps, the fridge resumed normal operation...
Old 08-24-2014, 10:14 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I will bet you "wiggled" something. Often connections "loosen" with time and moisture and heatcycles... Congrats!
Channing
WBCCI# 30676
Old 08-24-2014, 10:55 PM   #5
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Channing
Nice piece of trouble shooting on your part. That is what Air Forums is all about- wonderful caring people.
Dan
Old 09-08-2017, 05:23 AM   #6
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
EO error code
Went to turn on the refrig and got the EO code. First thing I did was pull the 12V fuse to check it's condition, fine replaced it check and the refrig turned on and has ran fine since. This is the RM3762 in our 15 Classic
rbs is offline   Reply With Quote
Old 05-08-2020, 07:03 PM   #7
369goose's Avatar
2014 25' Flying Cloud
1987 29' Sovereign
1978 31' Sovereign
Tampa Bay , Florida
E3 refrigerator code
My 2014 Flying Cloud is at inside storage and today when I went to do a routine check I found the refrigerator warm, at 60 degrees, and an E3 error code.
Any idea what caused this and how to clear it?
Would also be interested in any contact info anyone might have to reach Dometic Support or Customer Service.
Thanks all
☘ 369goose
"The world is a book and those who do not travel read only one page.” – St. Augustine
369goose is offline   Reply With Quote
Old 09-21-2020, 05:52 AM   #8
TeckTavern's Avatar
2018 28' International
2021 25' Globetrotter
Canandaigua , NC
Originally Posted by drew05 View Post
cwf,
Had the same issue and I was able to clear it by removing the DC power from the mother board. It seems an error code can get "stuck" in board memory and removing DC power to the board for 5 minutes or so clears the code....
TeckTavern is offline   Reply With Quote
Dometic RM3762 Error code E1 help Airstream01 Refrigerators 20 01-28-2019 11:01 AM
Error Code 299-Loss of Power milkfish888 Sprinter and B-van Forum 12 07-02-2014 05:57 PM
Onan gold5000, error code 14 kmamedia Land Yacht/Legacy Motorhomes 0 11-10-2008 11:06 AM
Error Code 127 in Classifieds 66Overlander Forum Admin, News and Member Account Info 3 11-30-2004 04:53 PM
